Workbench mesh Inflation Problem
1 Attachment(s)
I have a problem when trying to add inflation into boundary layer in the external section wall, while having face meshing into my fluid domain which i devided into 8 faces. the problem is that inflation and face mesh do not work together, and if i try to remove face mesh i am not be able to have structural meshing inside my fluid domain, any suggestions to have inflation while still having structural mesh ? |
Hi Med_91,
You can use a multizone meshing method (mesh > insert > method > multizone) and then "inflate this method". This should do the trick. Have fun ;) |
