Udf fluent: automating air flow in air duct
Need some help please, anyone.
Attached file shows a flow chart for a c++, with initial c++ code shown. Writing c++ UDF independent, since I will be compiling outside fluent first. Will adapt to udf fluent format later. A flow sensor measures air speed in duct. Based on preset airflow speed, pressure is adjusted by 10% (increase or decrease) depending on airflow speed. Increments/decrements of 10% per a loop is done per a conditional airflow check, till required airflow is achieved. The attached flowchart should clarify this. Thanks in advance. If you can't see attachment, will upload again. |
