how to save the variable values at some points every time step
Dear friends:
could you please tell me how to save the variable values at some points or lines every time steps. since the mesh size is very large. Regards |
in CFX-Pre create a Monitor Point with the desired expression or variable (pressure etc). In the solver manager, you can add a new monitor with that new monitor point. You can export the data for every time step from the solver manager as CSV-file.
Appart from the monitor points you can also extract these values from a transient run in cfx post by using perl scripts
Have a look at the thread http://www.cfd-online.com/Forums/cfx...tml#post385850 especially at the posted example file Maybe it could help you |
This I don't know.
But when you reach the end of your simulation, you have the whole progress of your monitored value, and you can export the whole curve / data set to the csv file. You don't need to do the export for each time step... |
