Elapsed time as outout parameter
Hey guys,
I was wondering if I could define the elapsed time of a simulation as an output parameter. It is quite annoying to select the current DP and switch to the monitors every single time for every single DP. Cheers Jacob |
"Time" is CFX output parameter that you can work with. Check the manual. You can extract that with cfx5mondata via command line as well if needed.
