UDF For Electrical Conductivity Not working
Hello All,
I was trying to create a UDF for electrical conductivity in a multiphase MHD simulation using DEFINE_PROPERTY. While the UDF gets compiled and loaded. It gives me an error as soon as I initialize/run or try to plot electrical conductivity. This is not working even if I give a constant as return in the UDF. The error I get is , "Error: received a fatal signal (Segmentation fault)." I am using 17.1. Thanks in anticipation. |
Check if all the information you use in your UDF is available. |
Thanks for the response. I have checked that. I just tried returning a constant value from UDf but it still did not work. In fact, the same udf when applied to any other material property is working but not for elec cond. Quote:
