Note: zone-surface
Hi
When for the second time I import Case and data, I face with the following note, Why? Preparing mesh for display... Note: zone-surface: cannot create surface from sliding interface zone. Creating empty surface. Note: zone-surface: cannot create surface from sliding interface zone. Creating empty surface. Thanks, |
Can no-one guide?
really I need to your guide. |
Is it a warning? are you using mesh interface?
No, it is not warning Yes, I am grateful that guide me |
remove all mesh interfaces in fluent, change all boundary conditions that are interface type to another type such as wall or pressure inlet
check your mesh again, Does the error exist yet? |
How to remove? |
use mesh interface tab in fluent and delete all of them
Periodicity conditions are imposed along the meridional surfaces delimiting the domain and distant 45 deg in the tangential direction. I done the works that you said, please see the following video file and I am grateful that guide me. http://www.4shared.com/video/-PKaGJG...titled_34.html Thanks, Best, Aja |
