Gambit: circular-rectang. transition
Does anybody knows how to built a volume in Gambit which is formed by a smooth transition from rectangular (not square) to circular contour (the laters' diameter is smaller than the sides of the former)? Thanks a lot.
Re: Gambit: circular-rectang. transition
I'm afraid that's not quite possible in Gambit. This is a job for much more professional CAD programs, like CATIA for example. There you could use a "loft" operation and your problem will be solved in a matter of seconds.
Best whishes, Razvan |
Thanks, I've done it in Solidworks. BTW, from square (not rectangular) to the concentric circle it is possible in Gambit through the variable radius feature. Regards, Alex.
