Blastfoam installation problem
4 Attachment(s)
Hello everyone
For my thesis at the university of Ghent. I need to work with the blastfoam software. I am trying to download the software but I keep having the same problem over and over again. Can someone help me with this problem and give me the solution? You can find the problem in the screenshots below. The problem occurs when I run the /.Allwmake command. Thanks a lot Pieter-Jan Hochepied |
Hello everyone,
I am facing the exact same problem. Cannot compile blastfoam after exactly following the steps listed in the blastfoam user's guide. I tried on Ubuntu LTS first under Windows 10, also under Windows 11 and now on a native Ubuntu installation. Always get the same error as to be seen in the pictures of the first post. OpenFOAM itself it running without any issues. I am desperate! Please help! I don't understand the error message -> "lookupTables/lookupTable2D/lookupTable2D.C:648:13: error: cannot convert ‘Foam::ITstream’ to ‘const Foam::word&’" and a whole host of other similar ones. Kevin https://easyupload.io/kget88 |
1 Attachment(s)
Here's a picture. Can anyone tell me what the error messages stand for and/or what can be done?
Thanks a lot in advance |
Heya folks,
I solved the "riddle" ... to my embarrassment, I have to admit I was using OpenFOAMv2112 when trying to compile blastfoam. I wasn't really aware of the differences between openfoam.org and openfoam.com. But of course, in the user's guide, it is stated that OpenFOAMv9 needs to be used in order to compile blastfoam. I was simply assuming I needed the latest version of openfoam to be installed. |
Dear foamers,
How to compile blastfoam and solids4foam? I have blastfoam 6 and openfoam 9 .. but I got stuck with the tutorial case of solids4foam. I didnot know about the solids4foam installation and compiling with blast foam.How to use stutorial case of solids4foam of blastfoam? I have used openfoam9 but I cannot run the tutorial case of solids4foam. It will help me for my research. |
