Why to take Normal to a surface...
I have written a Finite volume natural convection code for a square cavity using a structured cartesian grid using "Versteeg Malalasekara" as reference book. Now i am trying to do the same using an unstructured grid using "Blazek" as reference book. Blazek explained to take normal vector for each face. Why to do this. I never encountered this in "Versteeg". Can any one plz explain me this?.. |
You need the normal vector to compute the fluxes through the faces - that's how the fluxes are defined in the governing equations. If your previous experience is in structured Cartesian grids, the normal was hidden by the simplicity of the geometry.
The flux is a vector. For the entire quantity that goes through that surface, the normal component is needed.
Thanks to all for explanations. I clearly understood the meaning from jntan's explanation. I have to calculate (interpolate) the flux at a face by using the flow variables stored at two cells which share that same face and then multiple it by normal vector to get the normal component. is that rite?...
