Laminar simpelFOAM in Openfoam
Hi all,
I am trying to run a laminar simpleFoam simulation, but the simulation stops after running for the first time step. I get something like this when running the simulation: Timestep 1 <runs simulation> Timestep 2 Simulation STOPS without error I have set the following in the turbulenceProperties file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType laminar; // ************************************************** *********************** // and my controlDict setting are as follows: application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1; deltaT 0.001; writeControl timeStep; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 7; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 0.5; maxalphaCo 0.5; maxDeltaT 1; Please help me to solve this problem. |
application simpleFoam; Tom |
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0005283607, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0002620547, No Iterations 1000 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.01638241, No Iterations 1000 GAMG: Solving for p, Initial residual = 1, Final residual = 0.3576139, No Iterations 1 time step continuity errors : sum local = 79.94304, global = -51.76968, cumulative = -51.76968 ExecutionTime = 2254.25 s ClockTime = 2256 s Time = 2 |
Regards, Tom |
