paraFoam not working in Foam-extended 3.2
I am a newbie in the forum. I have installed foam-extended-3.2 in Ubuntu 16.04 version. Everything is going fine. I have done meshing and also run the simulation perfectly (I was doing cavity tutorial of incompressible icoFoam cases). Then, while I was writing 'paraFoam &' command in the terminal, paraview is opening but, shutting down instantly, showing the following message in the terminal: Quote:
Quick questions:
First I want to apologize for my late response as I was out for holiday. 1. Quote:
3. Quote:
I am also facing the same problem while using the foam extend 4.0. I have tried everything possible, I have also checked my installation comletely, and tried finding solutions in the forum. But no where it has been discussed. The error report as follows, /Work/tutorials/incompressible/icoFoam/cavity$ ERROR: In /build/paraview-arsa8T/paraview-5.0.1+dfsg1/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 310 vtkSISourceProxy (0x4304c10): Failed to create vtkXdmfReader. Aborting for debugging purposes. [1]+ Aborted (core dumped) paraview It would be really great if you can give me the solution. Thank you |
With Regard to above problem tried running, paraview a.foam now its working properly.
Osman, I am having the same issue. I had installed Paraview with OpenFOAM 5 previously before installation of Foam Extend 4.0. When I type the above commands, I receive the same message as you.
Thank you. |
I managed to fix it so that paraFoam command works with extend-4.0. I achieved this by modifying the PARAVIEW_DIR in the foam folder such that it calls the Paraview that was installed during extend-4.0 installation, rather than the newer version of Paraview from the previous OpenFOAM 5.0 installation.
Some of the details of this procedure were found online, but I can't seem to find a link for it right now. I hope this helps people that may have this issue in the future. James |
