paraFoam problem on MacOS after installing openFoam
Hi all,
I am fairly new with openFoam and I am trying to find my way through. I have installed the latest version of openFOAM OpenFOAM-v1812 following the guidelines from here:https://www.openfoam.com/download/in...binary-mac.php The installation was smooth and I was able to run perfectly the cavity tutorial (I can see the progress on the screen and the results in the directory). My problem is when I try to run paraFoam. What I initially got was (an apparently common problem) $ paraFoam $ Created temporary 'cavity.OpenFOAM' $ QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-ofuser' $ QXcbConnection: Could not connect to display $ /opt/OpenFOAM/OpenFOAM-v1812/bin/paraFoam: line 312: 836 Aborted paraview I then followed the guidelines from here: https://www.cfd-online.com/Forums/op...not-found.html and I now get a problem with some libraries $ /opt/OpenFOAM/ThirdParty-v1812/platforms/linux64Gcc/ParaView-5.6.0/lib/paraview: error while loading shared libraries: libmpi.so.12: cannot open shared object file: No such file or directory Do I need these mpi libraries for this? thanks a lot in advance! Panos |
Quick note: For future reference, PanosK found the answer in this post: https://www.cfd-online.com/Forums/op...tml#post705610 - post #5.
I cannot run paraFoam in Mac OSX
6451c6a70cbf: ~>> cd run/ |
https://develop.openfoam.com/Develop...raview-plugins |
It requires the selection of a reader. No one works. |
I managed to make paraFoam work in MacOSx after the installation of Paraview. Now I can use Paraview or ParaFoam.
ParaFoam is slower than Paraview. To use Paraview I had to change the extension .OpenFoam to .foam However, in SUSE SLES 15 Paraview does not work after installation. It appears to be a conflict between the OpenGL in the software and the NVIDIA driver of the OS. And I cannot install the new driver from NVIDIA because it says that GUI or NVIDIA persistenced or smi is being used. |
"paraFoam -vtk" |
