Probability density function
Hi All,
Is there any pre-implemented function to calculate the pdf (probability density function) of a given variable? I need something that does more or less what the matlab command "hist" does to calculate the pdf of the velocity during the run. Thanks Andrea |
pdfPlot
Application: pdfPlot Description: Generates a graph of a probability distribution function. $WM_PROJECT_DIR/applications/utilities/postProcessing/miscellaneous/pdfPlot Never used it though. Cheers Fabian |
Hi Fabian,
It seems a good starting point. Thank you for the hint. Best, Andrea |
maybe very stupid question...but how max and min function work for scalarField? To define my intervals i need to define the minimum and maximum of a scalarField. If i use min(myScalarField) or max(myScalarField) i get very strange numbers. So, do min and max work for scalarField and do they work also in parallel (do they perform reduce operations)? best, andrea |
gmin/gmax
Nope, min and max only work for one processor. For parallel runs you have to use global gmin/gmax functions.
Cheers Fabian |
