OpenFOAM solver for nonLinearAdvectionDiffusion equation
While learning openfoam programming module, i documented basic solvers which represents NonLinearAdvectionDiffusion equation.
Link to Documentation: https://rvadrabade.github.io/OF/NonL...usionFoam.html Link to test cases: https://rvadrabade.github.io/OF/Validation_nLAD.html Compared with c code output there is too much over and under shoot for upwind scheme and other schemes too . Do these result are valid? Do solver needs some improvement? Source code and test cases: https://github.com/Rvadrabade/OpenFO...nDiffusionFoam |
reply to nonLinearAdvectionDiffusion solver results
It seems it should be have decrease at velocity after normal shock; however, from the result cases, there are increasing velocity!
May be there are some mistakes in defining boundary conditions. |
Could you suggest correct/suitable boundary condition (s)?
