conservative form twoPhaseEulerFoam23x gives an unsatisfactory velocity result.
3 Attachment(s)
Hi guys,
Actually, After tons of simulations, I jump to this conclusion that: 1.conservative form twoPhaseEulerFoam23x gives an unsatisfactory velocity result.but keep the alpha field conservative. 2.twoPhaseEulerFoam 22x gives very precise velocity and turbulent field. but the alpha field is not very good. I mean, the dispersed phase's volume in twoPhaseEulerFoam 22x is missing. this is the problem. This is my comparison: my geometry is a simple stirred tank with 4 baffles and 6 rushton impellers, dispersed phase is oil. alpha volume fraction is 0.002. continual phase is water. and I do it with cyclic boundaries. In twoPhaseEulerFoam 22x. the velocity is like this(which is the same with the singlePhase simulation, cuz the dispersed phase volume is very low, 0.002): http://www.cfd-online.com/Forums/att...1&d=1419084298 which is the same with single phase simulation: http://www.cfd-online.com/Forums/att...1&d=1419084298 But in twoPhaseEulerFoam 23x. this is the slice of the velocity, looks like its a little sticky.I have tried with different turbulence model such RAS LES, all dont improve the velocity result.This is the typical velocity field: http://www.cfd-online.com/Forums/att...1&d=1419084298 Back to the problem of alpha. these two versions of calculated alpha field smoothly, but gives a different distribution(this maybe induced by different velocity field I mentioned above). In twopahseeulerfoam23x, alpha field is extremely homogeneous. this is what I expected. in 22x, its not homogeneous, but it also make sense. Apart from this, the really problem is: in 22x, the dispersed phase's volume is missing, in my simulation, the tank is closed. all walls boundaries and cyclic. so any phase can not get out the domain. These is the log of 22x: Code:
Courant Number mean: 0.0475877 max: 0.499942 Code:
Courant Number mean: 0.0334339 max: 0.499894 So for now, 22x twophaseeulerfoam gives amazing velocity field. but alpha is missing, 23x twophaseeulerfoam's alpha is stable, but the velocity field is not satisfactory. I also tried with the different composition of UEqn, PEqn, and AlphaEqn to make a new solver. and I found that, if the velocity is right, alpha is missing... Any comments is highly appreciated, |
2 Attachment(s)
After I post this thread, I think that maybe this maybe caused by the cyclic boundaries? So I tried with the whole geometry , pls see the picture of velocity field:
For now, time 4 sec, 22x behaves perfectly including alpha field, dispersed phase volume is not missing for now. is it caused by the cyclic boundary? I will keep it running and see. Update: dispersed phase's volume is still missing..... http://www.cfd-online.com/Forums/att...1&d=1419089349 the initial value of alpha is below 0.002 is because that I plot it from about 7 sec. it does not matter. http://www.cfd-online.com/Forums/att...1&d=1419099059 |
Update:
By looking the alpha's plot carefully. we can see its absolutely linear with Time. its going down stably. So I tried with run it with single core. This is solved. alpha is extremely stable to be constant for now. for now I dont have time to figure out why its happening with parallel running. but the velocity field in openfoam 23x has not been solved yet. Also I found that compressible effect is forced to switch on in twoPhaseEulerFoam23x. But I dont expect this compressible effect on my simulation. In conclusion(from my simulation): 1. twophaseeulerfoam 23x's velocity is not satisfactory. this will induce abnormal epsilon field. 2. parallel running can make the dispersed phase volume missing.(not only this, GAMG matrix solver is also not stable in parallel running.) 3. how can I switch off the compressible effect in twoPhaseEulerFoam23x? by the code it looks unlikely. |
1 Attachment(s)
I plot dispersed phase volume on openfoam 2.3.x.
http://www.cfd-online.com/Forums/att...1&d=1419410757 This is not the same with 22x. Its going down non-linearly. Also should be noticed that in 23x, there is an compressible effect which means rho will change somewhere. BTW, 23x is going down slowly. u can compare with this plot and the previous plot. This is why I can accept 23x. But 23x's velocity is not good. So here is my solution: 1. serial running on openfoam22x, this may take a long long time. 2. parallel running on 23x, alpha will be constant but the velocity.. 3. parallel running on 22x, velocity is extremely the same with the published paper. but alpha is not constant.... |
Update:
Anyone who is interesed into this thing can download the case from here. http://www.openfoam.org/mantisbt/view.php?id=1466 The dispersed phase volume missing is not the problem of the equations. because: in openfoam 22x, serial running is good and the data is almost the same with single phase simulation(This is the reason why Im using 22x not 23x). But parallel running the dispersed phase volume is missing! I tried with many method, modifying the mesh, do not use cyclic boundary condition, copy the physical properties form the tutorial, change the boundary condition, change fvShemes, change fvSolutions, change timePrecision and writePrecision(this maybe a clue) change the initial internal field of alpha. All does not work. But I found an interesting thing that: this value tends to change after the fourth significant figure. for example: 1. if the initial value of alpha is 0.002. from the log file we can see that it will change like this: 0.00199998,0.00199985,0.00199965,0.00199955. 2. if the initial value of alpha is 1e-09, it will be: 9.999708543e-10, 9.999532875e-10, 9.999330141e-10 So this maybe related with significant figure in C++? |
for now, im running with one core...
mesh cells : 58000. taking 3500s, I got 0.5s result. deltaT = 0.0005 Looks like I can should take a vacation to America!! |
Update:
Looks like this dispersed phase volume problem can not be handled in openfoam 22x. I guess I have simulated at least 50 different cases. So I decide to forget it to move along. Also, I found this velocity field simulated by openfoam 23x can not be cured. Even after this bug report, http://www.openfoam.org/mantisbt/view.php?id=1470 openfoam twoPhaseEulerFoam 23x still can not predict velocity precisely in stirred tanks. So I post another thread to figure out the difference between this two models: http://www.cfd-online.com/Forums/ope...ifference.html ...no one is using twoPhaseEulerFoam23x here? looks they are not interested into this problem.. best, |
Similar bug reports here:
http://www.openfoam.org/mantisbt/view.php?id=1685 http://www.openfoam.org/mantisbt/view.php?id=1700 Still not fixed, for now if I want my dispersed phase to be constant. I have to force it to be in the code. |
Hi Sharonyue,
Thank you for the great work you did. I'm using multiphaseEulerFoam (OpenFoam 2.3.0) to simulate a two phase flow (air and water for eg.). My problem is that the solver become unstable (Co number explodes) when I tun in parallel. Do you have an idea about the origin of the problem ? Thank you |
Hi Mehrez,
Maybe you can check your mesh's quality? Is it total hex? or with tet? |
Thank you for the quick answer.
The mesh is with tetrahedral elements. Do you think that using hexahedral elements is better ? Thank you. Mehrez Quote:
Yes Im sure it will be better! Especially for this solver. Enjoy.
Thank you for this important remark. In fact, I noticed that using Hex meshes improve the stability of the solver compared to tetrahedral ones.
But the issue is that the generation of Hex meshes is not easy when dealing with complex geometries... I'm trying to find the best fvSchemes to use with the multiphaseEulerFoam solver to ensure the stability of the simulation using tetrahedral mesh. I posted here: http://www.cfd-online.com/Forums/ope...tml#post594250 Thank you for your help, Mhrz Quote:
