Control simulation to apply different fields with chtMultiRegionFoam
Hi everyone,
i'm using chtMultiRegionFoam, with frozen flow, to solve a case where one valve opens and closes depending on the temperature on a specific location. I've solved two steady states simulations, which refer to the cases where the valve is open and closed, to obtain the flow field that is then used on the transient case. The procedure can be put like this:
My questions are: 1) Is there any function of openFOAM that stops the simulation when certain min/max value is obtained? 2) Copying the necessary files and restart the simulation could work? As the mesh is the same, mapFields is kind of unnecessary. 3) Feel free to refer any other way of doing this, it will be very helpful! /Regards |
