error::: Attempt to cast type wall to type lduInterface
hi all,
i want to simulate a case in which there are two separate region with ggi interface in OpenFoam-dev.. when i do foamToVTK i get following error.. can somebody help? Create time Create mesh for time = 0 Deleting old VTK files in "/home/Rohini/OpenFOAM/OpenFOAM-1.5/tutorials/turbFoam/porousnew/VTK" Time 0 Attempt to cast type wall to type lduInterface From function refCast<To>(From&) in file /home/Rohini/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/typeInfo.H at line 106. FOAM aborting Aborted |
Hi rcm, I got the same message error when I do foamToVTK, but when I take off my velocity field U from 0/ directory, it works...quite strange !
If you 've found the solution please don't hesitate to answer me, because I need my velocity ! regards Yann |
ok I've got a mistake in my U file, it was a problem of wrong patch, I wrote a cyclic patch instead of zeroGradient...
hi
i had the same problem and i solved it. you not only need to change all the internal boundary into cyclic but also you should change the boundary file in polymesh into cyclic |
