OF 1.6-ext: GGI-Check Problem with TransientSimpleDyFoam
has anybody an idea, why the function "ggi check" does not work in OF 1.6-ext for transient studies - and maybe how I can correct this problem? With MRFSimpleFoam it works perfectly! Thanks in advance. Regards Markus |
The search function is your friend - I asked this a while back
http://www.cfd-online.com/Forums/ope...t-1-6-ext.html The answer is there as well. |
I used the search function and know this modification. But no,that's regrettably not the answer!
I implemented it in the controlDict but it only works for steady studies (I tested it with MRFsimleFoam) but not during transient calculations with transientSimpleDyFoam! Regards Markus |
Markus,
My bad - I missed that point in your original post. Can you provide more information? What is the error? Paste the error or attach your controlDict and log file. -Chris |
ok it works from the second timestep but at the first one ggi check does not work.
