[ICEM] Wrapping mesh around NACA0012
Like Tree1Likes
Old   May 13, 2012, 16:38
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
give me boundary conditions
Far is offline   Reply With Quote
Old   May 13, 2012, 16:39
James Hetfield is on a distinguished road
boundary conditions:
1-CURVES ----> wall
2-INLET -----> velocity inlet: velocity = 90 for zero angle of attack in X-direction (it can be found for other angles of attack)
3-OUTLET ----> pressure outlet (atmosphere pressure)
James Hetfield is offline   Reply With Quote
Old   May 13, 2012, 16:49
Far
Sijal
can you show the convergence plot. whats the mach no. for this simulation?
Old   May 13, 2012, 16:52
what do u mean?
I just set the velocity at INLET and the fluid is air "density=ideal gas, viscosity=sutherland"
Old   May 13, 2012, 16:53
there is no option to set Mach No.
Old   May 14, 2012, 05:49
Default Farfield BC
  #26
E63 AMG is on a distinguished road
The outer boundary shall be modeled using Farfield BC. And, ofcourse you need Mach no for this.
There was tutorial on NACA 0012 Airfoil, with some AoA, using Fluent. You shall go through that for reference.
Originally Posted by James Hetfield View Post
what do u mean?
E63 AMG is offline   Reply With Quote
Old   May 14, 2012, 09:24
what is the difference if I use INLET and OUTLET boundary conditions instead of farfield?
Old   May 15, 2012, 03:14
Default Fluent Manual
  #28
To quote from FLUENT Manual:
Velocity Inlet BC:
" In this case, the total (or stagnation) pressure is not fixed but will rise (in response to the computed static pressure) to whatever value is necessary to provide the prescribed velocity distribution.
This boundary condition is intended for incompressible flows, and its use in compressible flows will lead to a nonphysical result because it allows stagnation conditions to float to any level. "
Based on the information provided in the thread, I had assumed that you are trying to solve the compressible flow problem. In the external flow problems, the stagnation properties remain constant.
Kindly refer to FLUENT Manual for selecting appropriate BC for the simulations.
Hope this helps for your project.
Old   May 15, 2012, 08:42
Andrey
Ralen is on a distinguished road
Originally Posted by Far View Post
check this mesh
How do you associate green edges to the curves of the wing? So, the edges coincide with the curves of the wing?
Ralen is offline   Reply With Quote
Old   May 15, 2012, 08:52
you're da man!
thanks
Im doing Compressible (Air, density=ideal gas, viscosity=sutherland)
Velocity Inlet BC:
Old   May 15, 2012, 08:54
I use Edit Edge-->Automatic Linear, exactly as Simon says in his tutorial
how am I supposed to do that? any better ideas? how about the leading edge facet?
Ralen likes this.
Old   July 10, 2015, 22:21
Aidan
aptahaney is on a distinguished road
check this mesh
Hi, I know this thread is old but I was hoping someone could provide me with a bit of insight, as I am also having difficulty with the validation of the NACA airfoil. I have been at it for months and I just seem to be getting nowhere.
I created a mesh in ICEM, based on Far's mesh example (in this thread) using the same sections, and number of nodes where I could. (I had to reduce it slightly as I needed to reduce the node quantities). I'm using the same domain shape as shown here, http://turbmodels.larc.nasa.gov/naca0012_val.html, but at a distance of 50 chord lengths.
I then ran this program using Realizable k-e, ideal gas, wind speed 87.64m/s (mach number 0.26), angle 8 degrees,
Boundary Conditions:
Inlet = velocity inlet
Upper & Lower Surfaces = velocity inlet
Outlet = Pressure far-field
However, I got a graph that will not converge, and in which the continuity equation value is actually increasing..... despite the fact that I followed Far's helpful model, as best as I could.
Can any one suggest where I may be going wrong on this? Is there an issue with my boundary conditions or something completely different??
I did try to change my upper and lower surfaces to a pressure farfiel but then I got divergence in the AMG Solver -> temperature...so I'm not sure if that is the correct thing to do. (in that case, I just turned off the energy equation until iteration 50 and then switched it on again, which resolved that problem but still didn't give me the correct answer, or anywhere near it)
I'd really appreciate any advice you that you may have at this, as I have been trying to solve this problem for a number of months now, and I have got no where, and as my thesis is due at the start of September, (and this is only one part of many), I am really up against it.
Thanks a lot.
Aidan
aptahaney is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
