[GAMBIT] cyclone mesh
Old   May 18, 2012, 00:48
Default cyclone mesh
masood
masoodina is on a distinguished road
hi . im working on cyclone . i have some problems in meshing it . i cant mesh inlet part of the cyclone either its not compatible or highly skewed . what must i do ? can i remove the inlet section and instead make part of the cyclone body as inlet (i mean something like a hole on the body) ?? does it effect the solution ?
2 . i have used some extra faces in order to mesh it radially ? will it make any problem ? do i have to use connect face for this ??(considering continuum )
here is a picture of the mesh :
thanks for your time .
http://img4up.com/up2/30055468416728292594.jpg
masoodina is offline   Reply With Quote
Old   May 21, 2012, 01:46
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
in your picture, you are displaying cells with skewness between 0 and 1... But this value cannot be greater than 1 or negative.
That's why you have 100% of cells between both values
So update your lower value with 0.9 instead of 0 (you will see all cells with skewness between 0.9 and 1)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
cyclone, highly skewed, mesh
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
Cyclone separator RSM mesh problem kharnab FLUENT 1 April 16, 2007 09:24
