[ANSYS Meshing] Reverse orientation option for periodic boundaries
Old   May 17, 2012, 06:10
Default Reverse orientation option for periodic boundaries
Cobain83 is on a distinguished road
hi,
is there in ansys meshing v14 an equal option for reverse orientation like in Gambit for periodic boundaries? I've linked my periodic faces with match control, but for OpenFOAM simulation it seems that I need those "reverse orientation" option to get it working.
Cobain
Cobain83 is offline   Reply With Quote
Old   May 18, 2012, 12:45
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I had no idea, so I asked around and got this back...
Is he doing an arbitrary match? I would think he should be able to do this by changing how the LCS is defined. Might need a model to understand what he is trying to do...
Unless you can get someone else to help on CFD-Online, you should probably contact ANSYS Tech support (even students qualify for tech support). You just need to get your customer number from the license file... Even if you don't have access to the server that the license is on, you can see it thru the ANSLIC_ADMIN utility by clicking the option to Display the License Server Machine Information (top button). Your customer number is listed at the top...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 18, 2012, 13:43
I get help from another forum user. I have to reorder my mesh, respectively the periodic boundaries in OpenFOAM. I will try it on monday.
Thanks for your help
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
