[ANSYS Meshing] How to mesh it
Old   May 19, 2015, 18:20
Default How to mesh it
Jodie is on a distinguished road
Hi to everybody!
Sorry for the newbie question, I'm still new in Ansys.
I have a problem with my mesh. I want to do sth like this:
It's my current model:
I've tried to do that with edge sizing, but I got triangles, not quadrangles
Thanks for any help!
Jodie is offline   Reply With Quote
Old   May 21, 2015, 00:38
amin.z's Avatar
Amin
amin.z is on a distinguished road
Originally Posted by Jodie View Post
Hi to everybody!
hi,
you have to slice your tube to a few patches!! I think 3 patches are enough,
as you've showed in the picture, but real patches! you need to have 3 separated bodies
then use sweep method and enjoy!
amin.z is offline   Reply With Quote
Old   May 22, 2015, 09:22
Javi
FJSJ is on a distinguished road
Hi Amin,
What meshing method are you using? I suspect you are using the automatic mesh generation option. If you want to get something like the picture you should use Miltizone and Hexa Dominant as Free Mesh Type option
FJSJ is offline   Reply With Quote
Old   May 23, 2015, 08:27
amin.z's Avatar
Amin
hi friend,
there are several ways for generating this mesh type, but I think more accurate way is 1st way, we can use sweep method over the circle curve!
in fact, if we performing a slicing on the cylinder (for example to 3 patches), we'll have 3 incomplete cylinders, then we can generate a mapped mesh on a longitudinal face then sweep it over 120 degrees circle curve.
Old   May 23, 2015, 20:15
Hi Amin
Thanks for Your answer! I've got small problem with the option "slice", in my project, it's unavailable:
At the moment, my tree outline looks like this:
(I've done this according to: https://www.youtube.com/watch?v=LAIB7qK-9pE 'coz I don't have the foggiest idea about ANSYS, I found this tutorial)
Could You help me and write step by step in some points what I should do? Maybe I've done this completely wrong?
Old   May 25, 2015, 01:35
amin.z's Avatar
Amin
well, look at this:
1. draw a circle at XY Plane
2. Extrude it
3. define a plane:
type: from plane
base plane: zx plane
transform: rotate about x
FD1: 120 degrees
Others: default
4. define another plane:
type: from plane
base plane: plane 1
FD1: 120 degrees
Others: default
5. define a slice:
Slice type: by plane
base plane: plane 1
6. define another slice:
base plane: plane 2
7. define another slice:
base plane: ZX plane
now you must have 6 slice with 60 degrees!
8. use boolean as unit and merge neighbor parts
now you must have 3 slice with 120 degrees
9. finally select the 3 parts and use form new part
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
