[GAMBIT] Mesh causes divergence
Old   June 15, 2012, 11:03
Question Mesh causes divergence
vlg
villager is on a distinguished road
Good day to everybody.
I've made a tetrahedral mesh in GAMBIT, non-structured, with sizing function - initial element size 0.1, step 1.1, max 0.2 form walls, geometry is several connected spheres with diam. 1 (united geometry). No highly (>0.97) skewed elements were found (but max skewness 0.77, mesh quality in FLUENT = 0.257). Then I've imported mesh to FLUENT to solve my problem with species transport. After twenty iterations some species (O2, hydrocarbons) residuals begin increasing, then all residuals start to oscillate at values about e-03.
I tried to repair mesh or improve it in FLUENT, and suddenly after restarting FLUENT, the problem solved.
I've created a new mesh with same size with periodic b.c., but the problem repeated, and here no action was helpful. Contours of species show that species concentrations are not adequate at one place of mesh (in fluid zone, where many very fine elements are connected together).
Can you explain, why it's happening? What meshing guidelines I've violated? Or how can I check & heal my mesh in GAMBIT for example?
Thank you very much, need your help.
villager is offline   Reply With Quote
Old   June 16, 2012, 14:08
Khayyamian
hadikhayyamian is on a distinguished road
This might be due to your inappropriate solver settings in FLUENT. you can lower amount of under relaxation for example.
hadikhayyamian is offline   Reply With Quote
divergence, mesh, skewness
About the divergence when using unstructured mesh Shamoon FLUENT 2 June 22, 2008 09:00
About the divergence when using unstructured mesh SHAMOON FLUENT 4 June 20, 2008 13:17
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
Mesh Mignard FLUENT 2 March 22, 2000 05:12
