[GAMBIT] Structured mesh around hole
Like Tree1Likes
  • 1 Post By -mAx-
Old   June 20, 2012, 07:44
Default Structured mesh around hole
prince
prince_pahariaa is on a distinguished road
Hey Friends,
I am trying to achieve structured (HEXA) mesh. Here is explanation of geometry.
There is a L pipe coming from outside and entering into rectangular pool. There is 10 nozzle mounted on the the part of pipe which is inside the pool (Nozzle is mounted on horizontal side).
I can create this simple geometry but i cannot create hexa mesh around it (near nozzle part and in rectangular pool as it was created by split operation). Can anyone suggest how to create (or decompose) geometry so that it can be structured mesh
If structured mesh is not possible suggest which mesh will be better.
prince_pahariaa is offline   Reply With Quote
Old   June 20, 2012, 09:16
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
pictures please
diamondx likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 21, 2012, 01:22
prince
Thanks Max..
Here is picture of my model..
Looking forward for any suggestion
Old   June 21, 2012, 01:44
-mAx-'s Avatar
Maxime Perelli
structured should be possible, but you will have to spend some time on it.
Else you can mesh it with tetra-hexcore with size functions
Decomposing your volume, will allow you to put more hexa subvolumes.
Mesh with tetra hexcore only, where you see you will have difficulties to mesh with hexa (especially a pipe junctions)
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
[ANSYS Meshing] Structured hexahedral mesh in workbench Chander ANSYS Meshing & Geometry 3 November 2, 2011 03:32
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 15:40
