[GAMBIT] meshing in gambit
Old   April 24, 2011, 13:31
Default meshing in gambit
maryam
fluid2008 is on a distinguished road
Hi
I am learning gambit,but I have a problem and hope you help me.
I want to make this mesh(the boundary layer about a sylinder)
but this picture is made i have a problem to setting point
what's the solution ?
fluid2008 is offline   Reply With Quote
Old   April 25, 2011, 15:49
etienne
hittie is on a distinguished road
split the circle in the middle to generate an O-grid. For the mesh in the central part you could mesh each edge separately.
hittie is offline   Reply With Quote
Old   April 27, 2011, 10:07
maryam
tnx you very much.but can you explain it more?
Old   April 27, 2011, 13:17
etienne
try to split the edge composing the outer circle (on the left of hte picture) in the middle. Do the same for the inner edge
Old   May 2, 2011, 06:43
Ammar Mushtaq
Ammar Mushtaq is on a distinguished road
Send a message via Skype™ to Ammar Mushtaq
Your every thing seem ok, here are few things that you need to do,
1: For outer semi circle region (extreme left) use double sided successive ratio for both small and large semi circles with appropriate same value for Ratio 1 and Ratio 2
2: For 4 end straight edges (extreme right) use same successive ratio and make sure that all edges have arrows in same direction.
I hope this would solve your problem, so
Ammar Mushtaq is offline   Reply With Quote
Old   June 26, 2012, 06:27
faizyab is on a distinguished road
seems like previous rplys didnt solve ur problem if i am right then can u further elaborate ur problem
faizyab is offline   Reply With Quote
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
urgent help needed for meshing in GAMBIT chris FLUENT 0 September 5, 2002 09:18
