June 14, 2015, 16:55 |
Curve Mesh Setup (dynamic) Problem
Allo Spizzo
Hi guys,
I am new to ICEM, so I'll try to explain my problem as clear as possible: I need to mesh a 2D cylindrical pipe (0.1 m diameter), so I did sketch a rectangular shape with height = 0.05 m (I want to simulate an axisymmetric flow so I'll draw only half pipe). The length of the pipe is what will "generate" my problem with this kind of meshing . In the first case I have L = 0.5 m and I setup the dynamic curve meshing as reported in the first picture. As you can see, the meshing process did ok. Since I need a much longer pipe (10 metres, the diameter is the same), I repeated the same process but I got the problem represented in the second picture, i.e. the number of nodes of the vertical lines is wrong (it was supposed to be 15 instead of 8). So does anyone know how to help me solve this ? I'm sorry if the question may seem stupid but as I said I'm an absolute beginner. Thank you very much for the attention ! |
June 15, 2015, 07:37 |
Global Mesh Setup > Shell meshing > Patch dependent > Respect line elements
And if you are a complete beginner you should be doing tutorials just to get a basic idea. From there you can move on to doing your own stuff. Just saying though |
June 15, 2015, 08:04 |
Allo Spizzo
Is my Dynamic mesh setup correct? | cfd seeker | FLUENT | 16 | October 30, 2020 06:16 |
Dynamic mesh Problem: How can I set UDF to the motion of train? | Majid Zarif | Fluent UDF and Scheme Programming | 4 | January 27, 2015 02:44 |
[Star-CCM+ v9] Dynamic Overset Mesh basic problem | johncoffey | STAR-CCM+ | 5 | June 17, 2014 14:14 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
CFD-3D flow problem using Dynamic mesh method. | Sar_mech | FLUENT | 1 | November 27, 2008 21:17 |
