[ANSYS Meshing] Error in facet normal for stl output of mesh
Old   July 25, 2012, 11:51
Default Error in facet normal for stl output of mesh
TWB
quarkz is on a distinguished road
I'm using ansys icem cfd to do my meshing. When I use stl for output, the resultant file has everything correct except for the facet normal.
If the meshing is done by ansys workbench and the mesh imported into icem, all the normal direction is opposite of the correct one.
However, if the meshing is done in icem, some directions are correct, while some are wrong.
How does ansys icem define the outward normal?
Btw, I'm meshing a naca0012 wing with sAR = 2, with the z direction from 0 to 2.
Thanks!
quarkz is offline   Reply With Quote
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Understanding check mesh output kotimari ANSYS Meshing & Geometry 0 July 15, 2012 08:33
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
