[Other] Recover the .msh from a .cas
Like Tree2Likes
  • 1 Post By Harshal
  • 1 Post By diamondx
Old   August 17, 2012, 17:48
Default Recover the .msh from a .cas
Mat
Mat_fr is on a distinguished road
Dear all,
I have a tricky problem to expose :
I would like to perform OF simulations starting from FLUENT data. However, I only have the .cas (also .dat) file. Indeed, the mesh was modified inside FLUENT (refinement, adaptation of cell size, etc), then the .msh file doesn't match with the simulation results.
Here, I have two possibilities :
* recover the .msh file from one of the ANSYS softwares
* convert directly the .cas file in OpenFOAM mesh.
I tried both of them without success for the moment.
As it is the relevant location of the thread, I will talk here about the first possibility.
Apparently it is possible to open directly a .cas file in icem or gambit, and then to save the mesh in a .msh file.
I tried with both softwares, but I get errors in all cases during the reading. I suppose it is due to the modifications on the mesh, performed inside FLUENT.
Here the ineternal error obtained in icem :
Not able to open file. Read error: wanted 1 bytes, errno 11
backend process has exited abnormally
Here the error obtained with gambit :
RAMPANT file to FIDAP7 file
File contains hanging node structure
Hanging nodes not supported
Does anyone have a suggestion for that ?
Thank you for your help.
Best,
Mat
Mat_fr is offline   Reply With Quote
Old   August 20, 2012, 06:38
L.Tuominen
tuominen is on a distinguished road
Try to save your .cas file to ASCII format in Fluent and then convert to OF format.
/ Lasse
tuominen is offline   Reply With Quote
Old   August 20, 2012, 07:14
Mat
Dear Lasse,
I already tried this without succes.
see my post here :http://www.cfd-online.com/Forums/ope...foam-mesh.html
Thanks,
Mat
Old   August 21, 2012, 06:33
Mat
Dear all,
I would like to try also with workbench.
So, I created a mesh system and I imported the .cas file. Then, the imported mesh is checked. Is it possible now to export a mesh file from that ?
There is no File -> export in workbench ??
I don't manage neither to open the default meshing tool of workbench (maybe one can export the mesh from there?)
Mat
Old   January 10, 2014, 08:47
Harshal
Harshal is on a distinguished road
Originally Posted by Mat_fr View Post
Dear all,
Mat
I know this post is old. But if you were able to solve this problem, can you please post the solution here. I am also facing the same problem as I am trying to import the .msh Fluent file in ICEM.
Thanks,
Harshal
rarnaunot likes this.
Harshal is offline   Reply With Quote
Old   January 10, 2014, 12:36
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
it's possible to retrieve the mesh file from the case in ICEM use the import function
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 11, 2014, 03:31
Harshal
I tried importing the .msh fluent file in ICEM using the Import from Fluent option. However, I am getting the same error.
Could you kindly guide me through this step ?
Thanks,
Harshal
Old   January 11, 2014, 11:18
diamondx's Avatar
Ghazlani M. Ali
I just tried it file-import-from fluent- and select the case file...
What kind of error are you getting
philocfd likes this.
Regards,
Ali
Old   January 11, 2014, 14:44
Harshal
I tried importing the .msh file from Fluent into ICEM using the Import mesh- From Fluent option.
In ICEM one can import either the geometry (Import Geometry) or mesh (Import Mesh-Import from Fluent)
When I try to import mesh from Fluent I get the error Not able to open file: Read error wanted 1 byte errno 11.....
How did you import the case file ? It is neither Geometry nor Mesh. I don't know from where I can import .cas file.
Thanks,
Harshal
Old   January 11, 2014, 14:46
diamondx's Avatar
Ghazlani M. Ali
create one case file with your mesh and just select it...
Regards,
Ali
Old   January 11, 2014, 14:52
Harshal
I did create a case file in Fluent. However, the method you suggested (File- import from Fluent) is not available to me. As I said for import there are two options: Import Geometry and Import Mesh- Import from Fluent.
Which ICEM version are you using ?
Thanks,
Harshal
Old   January 11, 2014, 15:35
diamondx's Avatar
Ghazlani M. Ali
that's weird , I have version 14.5 of icem...
Regards,
Ali
Old   January 12, 2014, 06:24
Tenglubao
philocfd is on a distinguished road
I've tried Ghazlani M. Ali's method ,for some kinds of fluent cases it works well ,but error occurs for particular cases.
philocfd is offline   Reply With Quote
Old   March 14, 2016, 13:37
Hooman
hooman.4028 is on a distinguished road
Open your .cas file in FLUENT (It has to be in Meshing Mode) and then save it as mesh (.msh).
hooman.4028 is offline   Reply With Quote
Old   January 11, 2017, 09:31
Yuehan
wc34071209 is on a distinguished road
Great! Problem solved!
wc34071209 is offline   Reply With Quote
Old   June 8, 2017, 03:44
Shashank
shashanktiwari619 is on a distinguished road
As suggested in above posts I tried exporting a 3D .cas file in meshing mode in fluent, but I get an error saying 'This is an educational executable, and can only be used \n with meshes containing less than 500000 cells or 50000\n unmeshed faces.'
also in case my .cas file is 2D I don't get an option for opening the file in meshing mode.
shashanktiwari619 is offline   Reply With Quote
how to convert Openfoam data to fluent .cas and .msh files sachinlb FLUENT 4 December 8, 2023 16:27
how to convert Openfoam data to fluent .cas and .msh files sachinlb OpenFOAM 1 October 25, 2011 11:52
[ANSYS Meshing] Export .msh file for fluent by script Mostapha ANSYS Meshing & Geometry 1 August 2, 2011 05:33
Problem with reading .cas and .msh file in ICEM CFD kbodla ANSYS Meshing & Geometry 3 March 14, 2011 15:50
Import .cas into Gambit Radi FLUENT 0 August 18, 2009 09:40
