[ICEM] Volume orientation
Old   September 19, 2012, 06:43
Question Volume orientation
MGF
Martina
MGF is on a distinguished road
Hi guys,
I know that this item has been discussed deeply in several previous posts but I haven't find there any suggestion which fits with my own problem so I hope not to annoying you and to find someone who can help me.
Please find the attached .png file named "geometry" which shows what I need to mesh. This geometry will be used both for a CFX and a Fluent simulation where a hot gas (let's say O2) will enter the channels and flow along the pipe. I attached also two pictures which depict my blocking strategy. Has anybody got a better solution?
I performed no smoothing. I just moved some vertices to obtain a mesh size as uniform as possible. I checked the mesh volume and found no negative volumes as you can see from the figure "volume_check" but had some problems with volume orientation which ICEM could not fix (see "volume_orient.png"). The quality for the elements highlighted in figure "volume_check" is poor but not negative.
I tried to run my simulation with this mesh but CFX gave me the following error:
| ERROR #002100011 has occurred in subroutine cVolSec. |
| Message: |
| A negative SECTOR volume has been detected. Execution will proceed |
| but this is a possible cause of robustness problems. |
| The location of the first negative volume is reported below. |
| Volume : -0.4257E-14 |
| This warning may be made fatal by setting the expert parameter |
| 'negative volume option = 1'. |
| ERROR #002100012 has occurred in subroutine cVolSec. |
| Message: |
| A negative ELEMENT volume has been detected. This is a fatal |
| error and execution will be terminated. The location of the first |
| Volume : -0.4237E-12 |
Does anyone have any suggestion about how to fix the problem?
Thanks in advance for any help.
MGF is offline   Reply With Quote
Old   September 19, 2012, 07:53
Christoph
energy382 is on a distinguished road
you've to block this geometry with quarter o-grid (y-grid) to receive reasonable results (angles etc.)
choose the 5 blocks of the pipe, transform to quarter o-grid and then extend splits.
Originally Posted by MGF View Post
Hi guys,
| Message: |
| Message: |
energy382 is offline   Reply With Quote
Old   September 19, 2012, 11:55
MGF
Martina
Hi Christoph,
thanks a lot for your suggestion! Managing to transform my blocks to quarter o-grids I discovered that I didn't merge some vertices on the axis and that was the cause in volume problems. However I fixed it and applied the Y-grid as you seggested and now the mesh can be correctly imported into CFX and simulated.
cfx error, icem cfd, icem mesh, negative volume element, volume orientation
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
