[ANSYS Meshing] LES mesh
Old   September 13, 2012, 11:36
Exclamation LES mesh
Hugh Ingham
martyn88 is on a distinguished road
Hi everyone,
I am attempting to simulate a turbulent free jet using LES but am having some problems with my mesh.
To create a periodic section of the full 3D geometry I am sweeping a 2-D structured mesh through a wedge. However close to the centre-line the cells become very high aspect ratio and I think this could be problematic.
Below are some pictures of my mesh:
As you can see in the 3rd picture I tried to slice the mesh just above the centre-line and mesh this small area with tet prisms as they capture the geometry better, however I think it is affecting my solution.
My pressure field is clearly affected by the interface between the tet and quad cell regions as can be seen below and I think it is also affecting my temperature field and causing my run to crash:
- Temperature hotspot forms (may be propagating from the strange pressure at inlet/centreline corner)
- velocity skyrockets
- density drops
- enthalpy equation crashes
Below are some pictures of this:
Could anyone please advise me on a good meshing strategy? What is the best way to deal with this tight geometry at the jet centreline?
Thanks,
Hugh
martyn88 is offline   Reply With Quote
Old   September 13, 2012, 12:28
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
What software did you use ?? Ansys meshing ?
Slicing is good step, then you have to use multizone method ? did you do that ? alse when you slice, the two bodies have to form one part in designmodeler ?
because of the triangular shape near the center line you need to add like a y-grid...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   September 13, 2012, 20:37
Hugh Ingham
Hi Ali, thanks for your reply.
I used Ansys meshing however I am importing the mesh into OpenFOAM for solution.
I sliced near the centre-line then swept the top geometries (10 divisions in the swept (circumferential) direction). I then sized the top of the sliced section (10 divisions) so that it matched up.
I am unfamiliar with the multizone method and the y-grid but I will research them and attempt to fix it today.
Thanks again
Old   September 13, 2012, 21:14
diamondx's Avatar
Ghazlani M. Ali
take a look at this post: http://www.cfd-online.com/Forums/ans...s-meshing.html
if you don't mind sharing your geometry i can try something in icem CFD...
Regards,
Ali
Old   September 14, 2012, 00:59
Talking
Hugh Ingham
Wow, that would be amazing. I will attach my geometry file (IGES format, I hope that works) and if you could have a go in ICEM that would be great.
In the mean time I will persist with Ansys Meshing
Brief description of the geometry:
- LES simulation (just working with really coarse mesh initially ~200k cells to establish stable BC's etc, but will refine mesh considerably later on ~3mil cells)
- converging-diverging nozzle surrounded by free stream
- require named selections for all of the boundary faces (later importing to OpenFOAM
- using wall functions initially at nozzle wall but will eventually solve all the way to wall
As I mentioned earlier, my main concern is with the highly skewed cells near the jet centreline, however I would like to maintain a structured mesh because I'm using LES.
LESfreejet.zip
Thanks again!
Old   September 14, 2012, 01:08
Hugh Ingham
So I had a look at the file you linked me. Can I create an o-grid on the 1/8th section I mentioned, ie would the square cells in the centre just be slightly skewed? I can not afford to mesh the entire geometry (LES will take far too long) so I was hoping to use a periodic section. Would a 1/4 section work better with the right angle at the centreline?
Cheers
Old   September 14, 2012, 13:55
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
here you go http://www.cfd-online.com/Forums/new...reply&p=381801
Far is offline   Reply With Quote
Old   September 14, 2012, 13:58
Far
Sijal
Cheers
Yes you can create o grid on 1/8th section. Now you decide how much angle is required to get the 3d effects for LES simulation.
Old   September 15, 2012, 03:34
Talking
Hugh Ingham
Thankyou Far and Diamondx!
I really appreciate it, I will run my simulation on the new mesh and see how it goes.
Old   September 17, 2012, 11:11
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Well this looks strangely familar..... Hope your making good progress
stuart23 is offline   Reply With Quote
Old   September 19, 2012, 05:21
Smile Getting there
  #11
Hugh Ingham
Hi everyone,
I am making progress however I am still having trouble grading my mesh.
Is ICEM in any way like ansys mesher where you can define an edge and a bias ratio etc? Because basically I need refinement at the nozzle wall and nozzle exit and also along the shear layer and inside the jet core.
If anyone has the time and could quickly have a look at it that would be amazing. I attached a link below which includes my project file.
I also attached a picture of how I would like the mesh graded (2D only but I hope you get the idea).
https://www.dropbox.com/sh/dtytfqs9j45zax9/bJJkiEB4iB
(the project file is in LESnozzle.zip and the picture is called desired_grading)
I also have one more question.
I require the two side faces to be periodic, and I set them as such in the global mesh set-up but I don't think it did anything. When I import into OpenFOAM it says the faces dont quite match up (0.4% error) and it suggests a possible face ordering problem. Is there a way I can establish a cyclic/periodic link between these 2 faces?
If anyone could help me out I would really appreciate it.
Thanks,
Hugh
Old   September 20, 2012, 12:44
diamondx's Avatar
Ghazlani M. Ali
defining a bias ration on an edge is one of the easiest thing. in the blocking tab, click on premesh-parametes, then click on edge paramater, on your bottom left you can choose bunching law...
Regards,
Ali
les grid, structured mesh
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Numerical oscillations in LES due to mesh refinement Soder OpenFOAM 0 June 14, 2011 10:10
LES mesh guidelines John Deas FLUENT 2 December 1, 2007 04:56
mesh requirement for LES Jason Main CFD Forum 1 February 10, 2004 16:48
