September 28, 2012, 03:30 |
Surface quad to tri split direction
Stuart
Rep Power: 25 |
Just made a quick surface mesh using autoblock with curve sizings to get quad elements. Then in edit mesh > convert mesh I changed the Quad_4 to Tri_3 (see image). Is there a setting to get all the Quad_4 elements to be split in the same direction into Tri_3, it seems a bit random in the image. Thanks |
[ICEM] Surface mesh not sticking to surface | holtwong | ANSYS Meshing & Geometry | 2 | April 20, 2023 08:28 |
[ICEM] how can i delect the duplicate mesh line and nodes in interface between quad and tri? | snailstb | ANSYS Meshing & Geometry | 10 | September 26, 2013 08:19 |
Plotting the velocity profile in normal direction along a curved surface | StSchiff | OpenFOAM | 0 | December 1, 2011 05:01 |
[ICEM] Split wall hexa mesh | Anorky | ANSYS Meshing & Geometry | 2 | March 21, 2010 10:33 |
Free - Surface Flow: Split Fluid Forces acting on a Boat Hull | eee | CFX | 2 | August 28, 2009 08:36 |
