October 10, 2012, 16:52 |
[GAMBIT] Map Meshing for cocentric cylinders
ali jafari
Rep Power: 13 |
hi
I used gambit and comsol for 3D map meshing for cocentric cylinders case , but I encountered with Error ! (gambit : " error : a logical cube for mesh was not able to found") please help me |
October 17, 2012, 02:11 |
Maxime Perelli
Rep Power: 41 |
pictures always help
In memory of my friend Hervé: CFD engineer & freerider |
October 17, 2012, 14:07 |
ali jafari
Rep Power: 13 |
October 18, 2012, 00:50 |
Maxime Perelli
Rep Power: 41 |
*try to delete the surface mesh of opposite cap (all surfaces mesheed execpt this one). Then try to mesh with cooper
*if not sucessfull try to split the volume on its symmetry, on mesh both volume *if not successfull you can send me your dbs file
[GAMBIT] Is GAMBIT really incapable of map meshing a subtracted surface? | Mojtaba.a | ANSYS Meshing & Geometry | 0 | August 16, 2012 08:04 |
[GAMBIT] hexahydral meshing of intersection of two unequal cylinders at right angle externally | animeshju | ANSYS Meshing & Geometry | 1 | August 17, 2011 08:27 |
[GAMBIT] Hexa meshing two intersecting cylinders in gambit | chat1983 | ANSYS Meshing & Geometry | 0 | April 8, 2010 07:38 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Gambit map meshing scheme | Juliana P | FLUENT | 2 | October 30, 2005 15:59 |
