[ICEM] Why the mesh changes after I save and open the project again
Old   July 19, 2012, 09:28
Question Why the mesh changes after I save and open the project again
lnk
lnk
lnk is on a distinguished road
I made mesh for a complex geometry by ICEM. After I improve my mesh quality, I save it. Then I open that project and check the mesh quality right afterwards. The mesh quality becomes bad.(By slightly changing it, it will be good again.) May I ask that's why and how to avoid this problem? After I improve the quality, if I export that mesh to CFX, am I exporting the good mesh or the bad one?
Best regards and many thanks,
lnk
lnk is offline   Reply With Quote
Old   July 23, 2012, 18:15
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
can you please be more specific?
Far is offline   Reply With Quote
Old   October 26, 2012, 12:22
Default Why the mesh changes after I save and open the project again
CFD-Cat is on a distinguished road
hey, I have exactly the same problem. Is someone able to explain me what I've done wrong or if it's a bug?
I produce my block mesh or unstructured, it doesn't matter, then i use the command smooth mesh globally (that works on the unstructured mesh) to gain a good quality, I save the project and close Icem. When i open the saved project and i check the mesh quality I get a really bad histogram worst than the one that I had before smoothing. It doesn't happen with all the project I've done but with most of them. I forgot to say that all the projects are based on the same geometry.
Thank you very much, regards
CFD-Cat is offline   Reply With Quote
Old   October 28, 2012, 23:31
nitin bansal
nitinbansal184 is on a distinguished road
Originally Posted by lnk View Post
lnk
Sometimes it happens to me....After conversion of premesh to unstructured mesh...Check quality several times
nitinbansal184 is offline   Reply With Quote
Old   October 29, 2012, 02:29
Nice I'm not alone! Anyone is able to give us an explanation?
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Question How to save Ansys 13 project to be opened by ansys 12 ? rafiktharwat ANSYS 3 July 17, 2017 21:09
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
Open ANSYS12.0 Workbench Project on another computer Andrew FLUENT 2 July 6, 2010 00:20
