[DesignModeler] Fill command with valve inside |
October 25, 2012, 01:28 |
Rep Power: 14 |
I cannot get the fill command to work with a valve piece inside. It just fills over the valve instead of creating empty interfaces where the valve is. Any ideas?
October 25, 2012, 02:26 |
Rep Power: 14 |
Figured it out, needed to use the Boolean subtract command
Simulation of air flow inside valve - FSI? Help! | farianka | Main CFD Forum | 0 | April 17, 2011 16:30 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Modelling the Heat flow inside the curing oven | Marios Vlad | CFX | 1 | February 6, 2008 07:11 |
[Technical] Flow inside a valve | danvica | OpenFOAM Meshing & Mesh Conversion | 0 | December 9, 2007 11:04 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
