[ICEM] merging meshs from different types of blocks
Like Tree3Likes
  • 2 Post By diamondx
  • 1 Post By BrolY
Old   November 8, 2012, 09:12
Default merging meshs from different types of blocks
kpax is on a distinguished road
hi everybody,
i am currently trying to mesh a bifurcating vessel using ICEM 14.0.
I managed to create a pre-mesh which seemed reasonable, but pre-mesh quality check tells me that i have some problems with skewness (equiangle skewness has more than 0.3% elements with skewness < 0.05). so i converted one of the blocks to type 'free' (all other blocks are 'mapped'). This reduced the number of highly skewed elements, but when i created the real mesh and checked it, the interface areas between the different types of blocks contained uncovered faces.
When I tried to convert the .msh file to use in OF (using fluentMeshToFoam), i got a weird error that did not occur for all mapped blocks.
so i think the problem is that the different types of blocks need to be connected in some way? I read in another thread that you can simply merge the nodes with a certain tolerance, but that did not work for me.
any help is appreciated.
kpax
kpax is offline   Reply With Quote
Old   November 8, 2012, 11:14
AB
BrolY will become famous soon enough
you could try this :
geometry -> create/modify curve -> concatenate/reapproximate curves
You will end with one curve, and it should work.
BrolY is offline   Reply With Quote
Old   November 8, 2012, 11:35
hmm, not sure what you mean? there is only one curve at the interface of the two blocks (which delineates different surfaces), so nothing to concatenate?!
edit: ok, maybe i should add some pictures. here you can see the blocking i chose (middle one is the free block), and the elements with uncovered faces.
Old   November 8, 2012, 12:55
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Basically, Uncovered faces means that you have volume elements with an exposed side. It should be covered by a shell or another volume element. Missing internal edges means that you have a 2D elements with an exposed side. It should be covered by a line element or another 2D element.
When you get either error (Uncovered faces or missing internal edges), you should push the [Fix] button. This will prompt you to select or type in a new part name. It will create shell elements (or line elements) to cover the "uncovered" faces (or edges) and put the new elements in the part name you selected. You will then have a valid boundary to take to Fluent and use as a wall or internal wall or whatever.
Simon
did you try this, when pushing the fix, name the new part "interior_something" then when setting boundary condition, declare that part as "interior"
Give it a try, you can share your project with us,i'll take a look at it when i have time.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 8, 2012, 13:00
diamondx's Avatar
Ghazlani M. Ali
Broly, it's either you're drunk or you're in the wrong thread :
http://www.cfd-online.com/Forums/ans...ter-curve.html
Far and BrolY like this.
Regards,
Ali
Old   November 8, 2012, 13:37
AB
Lol you are right Diamondx !
let's say I'm working too much
Far likes this.
Old   November 9, 2012, 06:23
hey ali,
this seems to be working, the only problem is that after this "fix" i get a multiple edges error. these multiple edges are located around the interfaces as you can see in the attached picture.
i think this is going in the right direction, because OpenFoam seemed to accept the interface internal BC... however, when trying to convert the mesh, i got
"Unused points found in the mesh, number unused by faces: 10444 number unused by cells: 10444"
I guess this is due to the multiple edges?
ps. i also tried putting all the surfaces in the same part, as suggested by simon here: http://www.cfd-online.com/Forums/ans...tet-merge.html
-> did not affect the multiple edge problem described above
edit: i just realized that it's only the middle block that makes problems. e.g., when i choose only the lower block (in the pictures) to be 'free', and the rest as 'mapped', then i dont get any uncovered faces at all. weird.
Old   November 9, 2012, 07:56
ok, i think i'm getting closer to the solution...
apparently, the critical step is when i convert the middle block from mapped to free. for some reason, this makes the block turn transparent on one side (see attached pictures). it's this step that leads to uncovered faces.
anyone seen this before?
edit: found a solution. separating the middle block into three parts and converting only the left and right one to type free works.. dont understand why exactly, though.
anyway, thx for your help.
Old   November 9, 2012, 11:00
AB
What you are experienceing is something I've ever wondered to myself.
For me, it's normal that ICEM sees uncovered faces considering the fact there are more cells on one side of the mesh than the other (the free block can have different number of nodes than the "structured" block).
This trouble is even more obivous when you use the option "refinnement".
That should be something the solver should handle instead of ICEM.
Do you agree with that ?
diamondx's Avatar
Ghazlani M. Ali
You did great while I was sleeping I'm glad you fixed your problem
Regards,
Ali
Old   November 9, 2012, 23:03
Far
Sijal
Do you access to Simon's tip and tricks where he showed the method to handle the full hexa meshing in similar cases
Where this converter is available?
Cant this problem be tackled with top-down approach more efficiently?
Old   November 13, 2012, 09:31
no, do you have a link?
It comes with OF, just type "fluentMeshToFoam mesh.msh" for a file named mesh.msh. usually works quite nicely.
could you explain that in a bit more detail?
thx!
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 09:04
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[blockMesh] Difficulty Merging Blocks lsingh OpenFOAM Meshing & Mesh Conversion 0 January 26, 2012 09:57
Merging the blocks in ICEM saisanthoshm88 ANSYS Meshing & Geometry 1 December 27, 2010 10:14
