[ICEM] Meshing prob at the surface joint
Old   November 9, 2012, 02:09
Default Meshing prob at the surface joint
S.Bogoda
sakurabogoda is on a distinguished road
Dear All,
I am trying to mesh a geometry by hexa grids in ICEM CFD. The problem happens in the connection of two cylinders.
There is an extended mesh in the connections.
(Please refer the attache files for the image views of connection, blocking and pre mesh)
Can any body help me to fix this problem?
sakurabogoda is offline   Reply With Quote
Old   November 9, 2012, 03:21
AB
BrolY will become famous soon enough
This has already be solved before. If you make a quick research, you should be able to find the link to this file "ICEMCFD_Tips&Tricks2010.pdf" made by Simon. Everything is explained in this document
BrolY is offline   Reply With Quote
Old   November 9, 2012, 03:28
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
create blocking for the bigger pipe including ogrid. Then create the blocking by extrude along curve. There are many other methods to blocks including first creating the one big block for both pipes. Just try.
Far is offline   Reply With Quote
Old   November 9, 2012, 04:10
S.Bogoda
Dear Boles,
I could find some presentations by Simon. But those cannot be downloaded. Can you please give me the exact link. I found this link,
ftp://ftp.ansys.com/outgoing/simon/ICEM_Tips2008.pdf
but cannot load the page.
Thank a lot for your help.
Sakura.
Old   November 9, 2012, 04:12
S.Bogoda
Dear Far,
Thanks for the hint. I'll try with it.
Old   November 9, 2012, 04:35
Far
Sijal
Originally Posted by sakurabogoda View Post
Dear Boles,
Sakura.
Simon told that ftp is closed permanently. Look for http link.
Old   November 9, 2012, 04:48
AB
https://securetransfer.ansys.com/bds...jbeilcchidej20
Old   November 9, 2012, 05:19
Far
Sijal
found it
https://docs.google.com/file/d/0ByIL...MjQ/edit?pli=1
Old   November 11, 2012, 06:52
S.Bogoda
Dear All, Thanks a lot for supports.
There is another prob with o grid generation.
01. First I blocked vertical cylinder, rotated it 30 degrees around Y axis and generated an o grid in it.
02. then, extruded the surface in to horizontal cylinder and split that block.
03. generated an o grid there. The problem occurred here.
Prob: When I created the o grid inside the extruded section, the o grid generate, but out side from the block. I haven't select "Around blocks"
Can anybody answer me why this is happening?
Old   November 11, 2012, 06:53
S.Bogoda
Old   November 11, 2012, 06:56
Far
Sijal
can you show the pics from different angles?
Old   November 11, 2012, 07:24
S.Bogoda
Dear Far,
Thank you so much for this immediate reply. I have attached all figures as steps I followed from jPEGs named ogrid0 to ogrid4.
Thanks again.
Old   November 11, 2012, 11:24
Far
Sijal
Pics are not clear. There are two tangential pipes going into the larger dia pipe?
Old   November 11, 2012, 21:11
S.Bogoda
Dear Far,
Yes, it has two tangential pipes joint. I have added more pics herewith. Still I cannot fix the solution.
Old   November 11, 2012, 21:18
S.Bogoda
This is how ogrid generated around the block. it is around the block. Still I cannot fix this prob.
Old   November 12, 2012, 02:36
AB
Associate first before doing the O-Grid and the extrude.
Old   November 13, 2012, 04:59
S.Bogoda
Finally I could fix it. It happens in split blocking and then extrusion. If the whole face extruded and then split it, ogrid generates inside the block. But I don't know what is the reason.
But thank you so much for your helps.
Old   November 13, 2012, 05:09
aysiyi
Aysiyi is on a distinguished road
i think when you extrude face ,did you choose the inherit part name option ?
Aysiyi is offline   Reply With Quote
Old   November 13, 2012, 05:21
S.Bogoda
Dear All,
I got a problem again. It is not relates to ogrid.
When I do the meshing, unwanted mesh extension generates from the cylinder top to bottom cone top curve. Pls refer the pics attached.
Can anybody help me?
Old   November 13, 2012, 05:24
S.Bogoda
Dear Aysisi,
There is no such an option in extrude faces. I used "Extrude alone a curve".
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[DesignModeler] Sweeping or surface meshing in enclosure? Edu-R ANSYS Meshing & Geometry 9 January 23, 2013 13:41
Shared surface between bodies for better meshing? alxe ANSYS Meshing & Geometry 5 August 18, 2011 11:52
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
