[ANSYS Meshing] Help me please!!
Old   November 23, 2012, 01:34
Default Help me please!!
jobito_2012
jobito_2012 is on a distinguished road
Hello everyone ... I wanted to ask if I can help me in to do two domains in fluent ... I need to model a flow through a series of tubes (photo), but do not know how to make the internal flow to make the mesh I hope I can help ... thank you in advance ...!
My solid is cooper and my fluid is water
Im sorry for my english...im learning too!
jobito_2012 is offline   Reply With Quote
Old   November 23, 2012, 09:07
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
In Design Modeler, try Tools > Fill
Choose "By Cavity" and select all the internal surfaces, then generate
jrunsten is offline   Reply With Quote
Old   November 23, 2012, 11:33
Default Hi!!
jobito_2012
I tried to do it but I can not select all inner faces ... you know how to select all interior faces?...
Old   November 23, 2012, 11:51
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
when you select one inner face, there is a tool that can help you "extend the selection to the limits" without having to select every face
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 4, 2012, 22:26
Default Hi !!
jobito_2012
mmmm, Thanks for your answer, helped me a lot, but I have a question ... I can not find the command "extend the selection to the limits" , where is that command? ...
Thanks again!
do not worry ... I'll find the command!! thank you!
