[ICEM] O-grid strategy
Old   November 28, 2012, 16:57
Default O-grid strategy
christine
yorelchr is on a distinguished road
Hello everyone,
I am trying to mesh a part of a geometry. I would like to use the block strategy or even O-block...but I am a bit lost and really "strange things" are coming out.
This is my geometry : http://cjoint.com/?0KCwDA1RElX
I don't know how to divide the domain : I've tried many things with no success.
I have divided the front plane in 9 (3 x 3 with ref to x by y for example) zones and the lateral plane in 6 (2x3 with ref to x by z) zones so that the internal tube is in the ( 2,2,1) zone. But then when I have to associate, I don't know how to proceed: http://cjoint.com/?3KCwWmveoP9
Thank you for any help
yorelchr
yorelchr is offline   Reply With Quote
Old   November 29, 2012, 00:49
Andrey
Ralen is on a distinguished road
Can you attach the geometry *.tin?
Ralen is offline   Reply With Quote
Old   November 29, 2012, 07:14
Andrey
I created geometry similar to this.
Old   December 1, 2012, 08:23
christine
ciao Ralen,
sorry for replying so late, but I had some other work to do and now I'm back again to this geometry. I've tried to send it to you but couldn't...I had the following message "invalid file". Well, I tried to do as you did. And I think I did not too bad. But when I try to read the mesh with Fluent I always have :
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
Preparing mesh for display...
Done.
Is there something to do after meshing when using blocks?
I can't see where I'm wrong, the mesh is clean...
Old   December 1, 2012, 11:16
christine
Here is the geometry with blocking and meshing.
Can anyone tell me what is wrong with it since I can't open the mesh on Fluent.
PS: the mesh is not really good but it's just a try version for testing the compatibility with fluent.
thank you
http://cjoint.com/?3LbrwbsQqX7
Old   December 1, 2012, 12:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Did you specify the periodic in mesh panel. What is the periodicity angle?
Far is offline   Reply With Quote
Old   December 1, 2012, 13:01
christine
ciao Far,
thank you for your reply.
I don't understand where I should put parameters for periodicity. In the BC panel I've put periodic but there's no way to specify the value of the angle.
When I do a mesh without blocking, I can read it in Fluent without specifying anything for the periodic surfaces. How can it be?
Old   December 1, 2012, 13:28
Far
Sijal
Minor issues :
1. Quality is low. Needed good topology
2. Current topology can also be improved by putting o-grid inside pipe.
Major issues.
1. Curves and points were part of surface and this is not good for defining the boundary condition. Put curve into seperate part say curves and points into points
2. Periodicity was redefined.
https://dl.dropbox.com/u/68746918/si...lar%20disk.rar
Old   December 1, 2012, 14:41
christine
1. yes the mesh is quite bad, but it's just for trying (I've spent time yesterday doing a "good" one to realise that Fluent couldn't read it so today I did all the blocking again without taking too much care on meshing).
2. I've put the inside pipe, seems ok for that.
1. About curves and points : I had made 2 parts for that but then ICEM created this "part.00" and put some staff in it: the curves and wall.125 and wall.126... Now I've changed that as you told me. I also checked with the files you've attached. Seems ok.
2. about periodicity: I've created the point (-45, 0,0) as the base point, then axis (1 0 0) with angle 45. But after doing the 4 pairs of points, horizontal lines have appeared as you can see on the picture : http://cjoint.com/?3LbuPedQhPw
And still no way to read the mesh in Fluent.
Old   December 2, 2012, 05:23
christine
when I do a check geometry, ICEM automatically recreates me this part.00 with curves from the inside pipe and with wall.125 and wall.126. Can it be a problem with that, for example "double curves" ?
When trying to read the mesh in fluent I have also:
Warning: Inappropriate zone type (periodic) for one-sided face zone 29.
Changing to wall.
Warning: Inappropriate zone type (periodic) for one-sided face zone 30.
Changing to wall.
Warning: Inappropriate zone type (periodic) for one-sided face zone 31.
Changing to wall.
Warning: Inappropriate zone type (periodic) for one-sided face zone 32.
Changing to wall.
Error:
Error Object: #f
Done.
Why would there be a problem with these periodic zones? I have given the 45 deg periodicity and created 4 pairs of points...
Any clue?
thanks a lot in advance
Old   December 2, 2012, 10:14
christine
ok problem solved !!!
when coupling points for periodicity I was taking 4 points not on the same surface but on 2 adjacent surfaces.
thank you very much for your help!!!
[ICEM] o grid blocking strategy? icemaniac178 ANSYS Meshing & Geometry 14 March 19, 2013 23:18
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
