[ICEM] Elliptical Geometry connector inserted in a pipe |
October 26, 2012, 17:12 |
Ali
Rep Power: 13 |
Hi All,
I am trying to mesh an elliptical entity which connects two pipes together for a confined flow turbulence study. It is protruding from one pipe and inserted into another. The problem is that ICEM somehow doesn't recognise the insertion! as shown in figure 1. is this a face association problem? Another problem is that on the narrow surface near the elliptical and pipe joints I get low quality mesh as shown in figure 2! I tried merging the ellipse on to the semi circle but that made everything worse as the mesh was originating from that point! my blocking approach was starting from the ellipse, creating an oring to represent the ellipse and then extruding the blocks to the inlet and outlet. Does anyone know how to fix these problems? I know the blocking needs a lot of improvements but I can't go much further without fixing these two main problems. The files are also attached! |
October 29, 2012, 00:57 |
#2 | |
nitin bansal
Rep Power: 13 |
Done in a single try..Reached minimum orthogonality 0.6 But mesh size around 2.7M. |
October 29, 2012, 05:26 |
Christoph
Rep Power: 17 |
October 29, 2012, 15:41 |
Ali
Rep Power: 13 |
Dear Alll,
Thanks for your effort! Nitinbansa: As the others have expressed your blocking approach does not include the most important features of the geometry. The elliptical entry, the insertion and the chamfer of the ellipse. I wish PSYMN took a look at this. I am getting the feeling that there could be a small glitch with ICEM in this case. because as far as I know the block has to be projecting the mesh onto the nearest surface and in the case of the insertion it is totaly ignoring it . May be I'm wrong about how ICEM works!!! I really appreciate any effort to help me with this geometry as most of my efforts are failing! Thank you! |
October 29, 2012, 17:18 |
Ghazlani M. Ali
Rep Power: 28 |
@ali what did you use to make the geometry ?
is the fluid domain extracted ?? meshing can be easy if fluid domain is extracted ... Can you share your geometry , if so can you export it in step ? |
October 30, 2012, 03:41 |
Christoph
Rep Power: 17 |
hey ali, I don't get your point. Why is it easier to extract a negative form (in fact you're using icem hexa)!? I've never done it before and I don't understand in which way it distinguishs from "normal" approach, as blocking should be the same.
October 30, 2012, 09:21 |
#9 |
Christoph
Rep Power: 17 |
If you've a very complex geometry with many geometry features, you can extract fluid volume (altough I prefer to build topology and delete unnecessary parts). But in this geometry, you don't need that. It will definitely not simplify the blocking.
October 30, 2012, 14:52 |
#12 |
Ghazlani M. Ali
Rep Power: 28 |
having some free time, i opened up the geometry in designmodeler, i couldn't understand which path fluid is gonna take... special where the arrow points.
December 6, 2012, 19:12 |
#13 |
Ali
Rep Power: 13 |
Hi All,
Sorry I have been away for a while and thank you for your efforts !!! Where you showed the arrow is sealed or if not sealed it is negligible for the sake of argument here, so the flow only goes through the elliptical opening !!! I actually solved this case by extracting the fluid domain and re approximating the elliptical shape where it attaches the circular curve so that I end up with angles higher than 9 degrees !!!! Other method was to use a hybrid mesh and fill the low angles with tets which wasn't exactly what I wanted to do !!! The most important thing was to associate surfaces with faces in the protrusion since the mesh does not recognise the protrusion. I will upload the mesh whenever get to my work computer!!! I would appreciate your opinions on the approach !!! Thank you very much everyone for your responses !!! |
ellipse, insertion |
blockMesh for a pipe Tee geometry | akluj | OpenFOAM | 3 | February 3, 2021 20:55 |
complete pipe geometry using mirrorMesh | megacrout | OpenFOAM | 0 | June 7, 2011 10:39 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
[Salome] Salome Geometry question (Pipe with certain wall thickness) | Hectux | OpenFOAM Meshing & Mesh Conversion | 1 | April 8, 2009 06:44 |
Restarted run and change in geometry...question | Vanessa | CFX | 3 | August 28, 2006 07:55 |
