[GAMBIT] Issue found with Create Boundary Layer (inverted airfoil) |
December 26, 2012, 10:53 |
susan
Rep Power: 14 |
I have found an issue while I was meshing an inverted airfoil. When I chose the “Create Boundary Layer” option, the “thickness” of that Boundary Layer was not “uniform”. Would you be so kind as to help me? Thanks in advance. …. This is what I have obtained: http://imageshack.us/photo/my-images/338/problem1d.jpg http://imageshack.us/photo/my-images/202/problemsn.jpg The two involved faces are: v_face29={AZ15,144Z15,edge 56,edge 58,edge 60,135Z9,BZ9,v-edge97 (unmeshed)} w12={edge59,edge52,134Z11,IZ11,IA (unmeshed)} http://imageshack.us/photo/my-images...w12faceamp.jpg Face v_face29: http://imageshack.us/photo/my-images/41/vface29.jpg “Zoomed” Face v_face: http://imageshack.us/photo/my-images/10/vface29amp.jpg Face w12: http://imageshack.us/photo/my-images/255/w12face.jpg “Zoomed” face w12: http://imageshack.us/photo/my-images/405/w12faceamp.jpg Create Boundary Layer data: First row a=0.0006 (m) Growth factor (a/b)=1.0206 Rows=19 Depth= 0.0137819 (m) Edges{edge.58,edge.60,edge.56,edge.59,edge,52} http://imageshack.us/photo/my-images...ylayerdata.jpg Face v_face29's edges data: AZ15: http://imageshack.us/photo/my-images/717/az15data.jpg 144Z15: http://imageshack.us/photo/my-images/17/144z15data.jpg edge 56: http://imageshack.us/photo/my-images/18/edge56.jpg edge 58: http://imageshack.us/photo/my-images/268/edge58v.jpg edge 60: http://imageshack.us/photo/my-images/542/edge60.jpg 135Z9: http://imageshack.us/photo/my-images...5z9datawen.jpg BZ9: http://imageshack.us/photo/my-images/803/bz9data.jpg v.edge97: Unmeshed Face W12's edges data: AZ15: See above (Face v_face29's edges data) 144Z15: See above (Face v_face29's edges data) edge 59: http://imageshack.us/photo/my-images/100/edge59data.jpg edge 52: http://imageshack.us/photo/my-images/707/edge52data.jpg 134Z11: http://imageshack.us/photo/my-images/715/134z11data.jpg IZ11: http://imageshack.us/photo/my-images/853/iz11data.jpg IA: Unmesshed invertedairfoil.zip: invertedairfoil.dbs invertedairfoil.jou invertedairfoil.lok invertedairfoil.trn http://www.mediafire.com/?j47asxx57b6mak7 ...... Greetings |
January 3, 2013, 01:46 |
Maxime Perelli
Rep Power: 41 |
did you try to attach BL prior meshing anything?
On your first picture we can see an edge (in front of your leading edge) which appears blue (which means meshed) So your BL has to deal with this meshed edge...
In memory of my friend Hervé: CFD engineer & freerider |
January 3, 2013, 06:55 |
susan
Rep Power: 14 |
Hi -mAx-
I did not. I meshed first the edges and then I attached the BL. I'll try your advice. I am very grateful to you for your help. Regards, Susan. |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
Questions about Boundary Layer Thickness and Turbulence Models | famerfamer | STAR-CCM+ | 3 | July 12, 2012 09:47 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
