[ANSYS Meshing] meshing for dual cell heat exchanger
Old   December 29, 2012, 10:19
Default meshing for dual cell heat exchanger
sandeep sethi
sandeep sethi is on a distinguished road
i am designing a heat exchanger. a helical coil is inside a cylinder. water at different temp. will flow in the helical coil and cylinder so heat transfer will take place. i want to use dual cell heat exchanger. it is necessary to get the overlapping mesh of helical coil wall surface. the helical coil surface mesh should be common for heat transfer. how to get that one. iam getting mesh for both part without overlapping..ansys 13. how to overlap in ansys 13.
my e mail is sandeepsethi910@gmail.com. please help it is my final year project.please help.. i want the overlap mesh .the helical surface will overlap ..the cells of helical coil surface should be common for both helical and cylinder
sandeep sethi is offline   Reply With Quote
Help needed in using wall BC for heat transfer analysis of heat exchanger tubes hassaan FLUENT 2 June 25, 2013 07:05
[Other] Meshing Techniques for Heat Transfer with Cube Shaped Objects cbritan OpenFOAM Meshing & Mesh Conversion 4 March 2, 2011 01:12
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 25, 2011 23:26
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
heat exchanger S K Prasad Main CFD Forum 0 November 14, 2006 03:16
