[DesignModeler] having problems with filling geometry
Like Tree4Likes
Old   January 7, 2013, 12:26
Default having problems with filling geometry
Michal
magnusDux85 is on a distinguished road
Do you have any idea how to fill volume in such model?
http://postimage.org/image/n6afdoa91/
Thank you
magnusDux85 is offline   Reply With Quote
Old   January 7, 2013, 13:24
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
very complex geometry, you will have to close all the holes and opening and use the fill option. After getting your fluid domain, the geometry will not be suitable for simulation since you need an extended outlet section.
I would have extrude a big cylinder useing the frozen feature, then make a boolean operation...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 7, 2013, 15:34
Michal
It is no so easy, as I thought, my model is here:
http://www.sendspace.com/file/qaywo4
because I want to add inner fluid domain not only fill!
Old   January 7, 2013, 15:41
diamondx's Avatar
Ghazlani M. Ali
i've never been able to import the soliworks geometry, guess it takes me a license to do that (maybe)... did you try my suggestion: here is a video describing the process:
http://www.youtube.com/watch?v=Bb8Tsd9eGe4
Regards,
Ali
Old   January 7, 2013, 15:54
Michal
yes I was trying but I would like to have only inner volume it means: fluid domain + geometry
thank you!
Old   January 7, 2013, 15:59
diamondx's Avatar
Ghazlani M. Ali
this is when the add frozen is suitable. you will have two bodies. just delete the one that you don't need. if you could import you geometry, please send me the AGDB file so i can take a look at it. not the solidwork file
magnusDux85 likes this.
Regards,
Ali
Old   January 7, 2013, 16:08
Michal
Thank you for your helpful assistance, file is here:
http://www.sendspace.com/file/o8b8wo
Old   January 7, 2013, 16:31
diamondx's Avatar
Ghazlani M. Ali
something like this
HEre is the file:
https://dl.dropbox.com/u/35161486/aero-engine.agdb
Regards,
Ali
Old   January 7, 2013, 16:32
diamondx's Avatar
Ghazlani M. Ali
i'm going back home, getting back to you once i'm there...
Regards,
Ali
Old   January 7, 2013, 16:41
Michal
yes nice, there is only one option cut off all outer fluid and leave casing and inner fluid, what do you think?
Old   January 8, 2013, 04:07
Michal
diamondx: do you have fixed idea how to remove fluid behind casing?
Old   January 8, 2013, 09:29
diamondx's Avatar
Ghazlani M. Ali
the slice feature allows to do that...you just need to select the plane or the surface on which the slice will be performed... give it a try since i'm not sure how you want you inner domain to extend at the outlet
Regards,
Ali
Old   January 8, 2013, 09:40
Michal
I was trying but I am not master in this matter ;/ -> http://postimage.org/image/7umpkwifr/
Michal
Fluid has to be removed from both sides
Old   January 8, 2013, 09:47
diamondx's Avatar
Ghazlani M. Ali
understood, if you really wanted that way... i can only think about performing several slices... and yet still not sure it will give us the right geometry. let me think about something else. i will get back to you when i've got a solution for this. i have some business to deal with... i will try my best....
Regards,
Ali
Old   January 8, 2013, 12:54
diamondx's Avatar
Ghazlani M. Ali
do you want something like this ??? keep in my that you are keeping all the geometry feature. which can be difficult to mesh. like the region where the red arrow points:
Regards,
Ali
Old   January 8, 2013, 12:57
Michal
Red arrow indicate another body which will be suppressed I would like to have fluid domain plus casing Casing is suppressed in this case, is it?
Old   January 8, 2013, 13:03
diamondx's Avatar
Ghazlani M. Ali
no it is not...
here is the file:
https://dl.dropbox.com/u/35161486/aero-engine-2.agdb
you will notice a lot of work in it. actually i gave up on slicing and deciding to closse the hole. then i gave up on the fill feature. i used sweep, then a boolean operation. very fast and easy...
Good luck with meshing process.,, we will be there to assist too
Regards,
Ali
Old   January 8, 2013, 13:05
Michal
Thank you your support was invaluable!
Old   January 8, 2013, 13:07
Michal
Under link there is no file...
[DesignModeler] Fill tool - grouping the faces of a complicated geometry? HeikkiT ANSYS Meshing & Geometry 8 July 20, 2016 07:37
Having problems creating a hole in a geometry of a meshed case zaidhadi FLOW-3D 3 April 4, 2016 16:49
[ICEM] Geometry accuracy problems crook108 ANSYS Meshing & Geometry 0 November 26, 2012 06:48
help plz! problems in filling times : new user shankar FLUENT 0 July 24, 2003 12:58
Adaptive optimization of geometry Jan Rusås CFX 1 September 16, 2000 02:38
