[GAMBIT] Mesh Generation
Like Tree1Likes
  • 1 Post By cfd seeker
Old   January 13, 2013, 03:51
Default Mesh Generation
India
Avinash is on a distinguished road
Hey..
I have calculated value of wall distance (Y) with the help of Y+ formula.
Now i want to put this during mesh generation in GAMBIT, can some body plzz help me out how to put this wall distance in GAMBIT during mesh.
& also help me out to understand what actually Y(wall distance) is.
Avinash Chandra
Avinash is offline   Reply With Quote
Old   January 13, 2013, 10:42
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Y+ means the height of the first cell from your wall. look for first cell height in GAMBIT... sorry as i don't use it.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 13, 2013, 13:01
cfd seeker is on a distinguished road
This wall y+ parameter is used in boundary layer theory for wall bounded flows. It is a non-dimensional distance from the wall to the nearest cell, mathematically defined as :
y+ = y*uf/v where uf is frictional velocity and v is kinematic viscosity
Actually it is used to define the different regions of the boundary layer i.e
For wall y+ <5, it is viscous sublayer, flow is mostly laminar here and viscous stresses are dominant.
For wall 5< wall y+ <30, it is intermediate layer known as buffer layer
For 30< wall y+ <300, it is fully turbulent region also known as log region, turbulent stresses are dominant here.
You can calculate y i.e height of the first cell for your desired wall y+ and then put this distance as "a" in "Boundary layer"(boundary layer is name of command(tab)) in Gambit
redchan0209 likes this.
cfd seeker is offline   Reply With Quote
Old   January 14, 2013, 01:26
-mAx-'s Avatar
Maxime Perelli
that's the way
[ANSYS Meshing] Question about mesh generation learning lnk ANSYS Meshing & Geometry 2 July 7, 2012 06:45
ISAAC code mesh generation morteza08 Main CFD Forum 0 June 15, 2012 09:26
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
