January 14, 2013, 10:43 |
Blocking with 2 fluids
tetsuya
Rep Power: 14 |
Hi.
I'm now trying to make a mesh with 2 fluid (fluid and aluid 2) With a fluid(fluid), I could make a mesh correctly, but chose some blocks as fluid2, then mesh has a problem like a picture. Can anyone tell me how to resolve it? Regards. |
January 14, 2013, 11:40 |
tetsuya
Rep Power: 14 |
Hi diamondx.
Thank you for your reply. I think I did it. Regards. |
January 14, 2013, 12:04 |
tetsuya
Rep Power: 14 |
I found maybe I think I need face between fluid and fluid2.
Is that right? |
January 14, 2013, 12:07 |
Ghazlani M. Ali
Rep Power: 28 |
if you do the association with the right curves, the face's association are done automatically with the nearest surfaces. if you still found problem you can post your tin and blk file i'll take a look at it
January 14, 2013, 12:08 |
Rep Power: 13 |
Yes. A surface should be given between the different regions.
January 14, 2013, 12:30 |
tetsuya
Rep Power: 14 |
Hi chaolei,
Thank you for your kind reply. So then, I think I need to select boundary type for the mid-surface as interior in Fluent, right? |
January 14, 2013, 12:31 |
#8 | |
Ghazlani M. Ali
Rep Power: 28 |
January 14, 2013, 12:37 |
#9 |
Rep Power: 13 |
If the grid nodes of both sides are matched, Fluent will think it is a interface. You do not need to give any boundary condition for it. I only deal with multi-zone (fluid and solid), I never simulation a case involving two fluids.
January 15, 2013, 07:05 |
#10 |
tetsuya
Rep Power: 14 |
I could do it!
Thank you everyone. |
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator | Crank-Shaft | ANSYS Meshing & Geometry | 5 | January 17, 2016 23:29 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 17:27 |
[ICEM] Blocking strategy | BrolY | ANSYS Meshing & Geometry | 0 | July 22, 2010 04:46 |
Differents fluids separated by wall | phil | FLUENT | 0 | January 18, 2007 02:43 |
