[ICEM] Blocking with 2 fluids
Old   January 14, 2013, 10:43
Default Blocking with 2 fluids
tetsuya
tetsuya is on a distinguished road
Hi.
I'm now trying to make a mesh with 2 fluid (fluid and aluid 2)
With a fluid(fluid), I could make a mesh correctly, but chose some blocks as fluid2, then mesh has a problem like a picture.
Can anyone tell me how to resolve it?
Regards.
tetsuya is offline   Reply With Quote
Old   January 14, 2013, 11:13
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
looks like associations are not done. associate edge to curve
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 14, 2013, 11:40
tetsuya
Hi diamondx.
Thank you for your reply.
I think I did it.
Regards.
Old   January 14, 2013, 12:04
tetsuya
I found maybe I think I need face between fluid and fluid2.
Is that right?
Old   January 14, 2013, 12:07
diamondx's Avatar
Ghazlani M. Ali
if you do the association with the right curves, the face's association are done automatically with the nearest surfaces. if you still found problem you can post your tin and blk file i'll take a look at it
Regards,
Ali
Old   January 14, 2013, 12:08
Chaolei is on a distinguished road
Yes. A surface should be given between the different regions.
Chaolei is offline   Reply With Quote
Old   January 14, 2013, 12:30
tetsuya
Hi chaolei,
Thank you for your kind reply.
So then, I think I need to select boundary type for the mid-surface as interior in Fluent, right?
Old   January 14, 2013, 12:31
diamondx's Avatar
Ghazlani M. Ali
tough i never made a simulation with two fluid, i guess your surface is an interface between two fluid you will have to set it as interior...
Regards,
Ali
Old   January 14, 2013, 12:37
If the grid nodes of both sides are matched, Fluent will think it is a interface. You do not need to give any boundary condition for it. I only deal with multi-zone (fluid and solid), I never simulation a case involving two fluids.
Originally Posted by tetsuya View Post
Hi chaolei,
Old   January 15, 2013, 07:05
tetsuya
I could do it!
Thank you everyone.
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator Crank-Shaft ANSYS Meshing & Geometry 5 January 17, 2016 23:29
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) Touré ANSYS Meshing & Geometry 2 August 5, 2012 17:27
[ICEM] Blocking strategy BrolY ANSYS Meshing & Geometry 0 July 22, 2010 04:46
Differents fluids separated by wall phil FLUENT 0 January 18, 2007 02:43
