January 18, 2013, 05:11 |
problem in meshing
tmeysam92
Rep Power: 14 |
Hello all,
I meshed the geometry(FIG.1) in ICEM CFD. but the mesh is not good(FIG.2). How can I solve the problem. thanks in advance. |
January 18, 2013, 05:13 |
tmeysam92
Rep Power: 14 |
the tin and prj files are here.
January 18, 2013, 06:00 |
Alexander
Rep Power: 16 |
I've got only ANSYS 13. So can you export geimetry to IGES or STEP.
I've got some time and can help you. |
January 18, 2013, 08:46 |
Alexander
Rep Power: 16 |
In attach file. You can find the solution of your problem.
Pospelov Alexander. |
January 18, 2013, 09:13 |
tmeysam92
Rep Power: 14 |
January 18, 2013, 09:28 |
Alexander
Rep Power: 16 |
So. In my file you can fine enother topology for your part. Look at it more carefully and you will see the defferece.
January 18, 2013, 09:33 |
AB
Rep Power: 21 |
tmeysam92, you didn't add your .blk file in the archive. If you don't want to, you could post a picture of your blocking.
But it looks like either you didn't associate an edge, either you forgot to add a split .. not very easy to say without .blk file or picture of your blocking. |
January 18, 2013, 13:21 |
#8 | |
tmeysam92
Rep Power: 14 |
i attached tin,prj and blk files. |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 20:03 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
