January 30, 2013, 14:47 |
Yet another opinion on a blocking
Ghazlani M. Ali
Rep Power: 28 |
Dear friends,
I have this geometry, project file is here https://dl.dropbox.com/u/35161486/He...%20quarter.zip here are some screenshot of the geometry and the blocking : I spent a lot of times trying to improve the quality, ended up finally wondering if the blocking was good enough. Can you help me improve the quality ? i now it can be one of the hardest task ! Please feel free to suggest any other strategy. Here again, i decided to mesh one quarter, i will mirror the mesh later to get the full mesh. i find it easier this way as i have to deal with less holes... Thanks a lot |
January 30, 2013, 15:14 |
Ghazlani M. Ali
Rep Power: 28 |
You see that left bottom small circle, too much elements are there, and i can't do anything about because of the parallel edges. this why i asked about the refinement in the other thread, i'm planing to use a refinement of 1/2 there...
January 30, 2013, 15:20 |
#6 | |
May be using some other topology resolves this problem... |
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator | Crank-Shaft | ANSYS Meshing & Geometry | 5 | January 17, 2016 23:29 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 17:27 |
[ICEM] Blocking For Swept Wing | air_engineer_arsenal | ANSYS Meshing & Geometry | 13 | July 24, 2012 11:52 |
[ICEM] Blocking strategy | BrolY | ANSYS Meshing & Geometry | 0 | July 22, 2010 04:46 |
