[ICEM] How to calculate the volume of mesh
Like Tree2Likes
  • 2 Post By Far
Old   February 7, 2013, 05:17
Default How to calculate the volume of mesh
AB
BrolY will become famous soon enough
I would like to calculate the volume of my mesh (blocking were used to create the mesh).
I know ICEM is unitless, but I ensured that mesures were in meters.
So as an example, for a cube, I know the volume is given by "length x length x lentgh". But I would like to calculate the volume throught the mesh or the blocks.
Do you know if it's possible and how I could achieve that ?
BrolY is offline   Reply With Quote
Old   February 7, 2013, 05:34
AB
I think I found how to do this.
- Create a part with the blocks you want to calculate the volume of.
- Convert the blocking to unstructured mesh.
- Right click on the created part ("Parts" in the display tree) -> Info.
Old   February 7, 2013, 09:04
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
the volume of mesh = volume of geometry, no ?! why would you need a volume of mesh ? without being intrusive
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   February 7, 2013, 09:07
AB
Yes volume of mesh = volume of geometry.
I took a very simple example of a cube, but my geometry is far more complexe than a cube
Old   February 7, 2013, 10:47
diamondx's Avatar
Ghazlani M. Ali
understood...
Regards,
Ali
Old   February 7, 2013, 12:08
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Broly : If you take ICEM along with complicated volume to Euclidean space and apply Euler volume law (along with Newton's calculus and Einstein's Solid differential geomtry) you can easily find out the volume of that mesh
These were just funny lines. cannot you select the particular (or all) block(s) and get all the info?
BrolY and virgy like this.
Far is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[blockMesh] Problem with Mesh Volume seboxx OpenFOAM Meshing & Mesh Conversion 3 January 30, 2012 08:19
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
ICEM 12 CFD help creating volume mesh from stl EmpError ANSYS 0 November 13, 2010 06:38
