[ANSYS Meshing] Unable to improve orthogonal quality in the compressor blade |
May 22, 2022, 14:23 |
Sakun
Rep Power: 6 |
I am doing 3D mesh on naca65-009 compressor blade in ICEM. i as shown in the pictures orthoganal quality is very poor on the blade surface. 1st create a 2D mesh and then i extrude 185mm. Eventhough i associate edge to cure and faces to surfaces. i still can not get the orthogonal quality from 0.0014 to 0.1 i did even increase the number of nodes on both x and z direction but no improvement. My 1st layer thickness on the blade is 8.06e-06 and growth ratio is 1.15. (quality-0.77 , skewness-0.75) can someone please help me on this? it is urgent and i spend so much time to solve this issue. |
May 26, 2022, 10:31 |
Alain Islas
Rep Power: 6 |
Please post some images of your blocking
May 27, 2022, 09:48 |
blocking images
Sakun
Rep Power: 6 |
i can send you the block and tin files as well.
May 29, 2022, 07:41 |
Chrowale
Rep Power: 4 |
Could probably due to block in LE and TE of the airfoil being so squished, try to move the boundary layer vertices away from the airfoil.
Very low 1st layer t/c also could lead to this, I still don't have an answer nor suggestion for this though. |
May 29, 2022, 09:20 |
Sakun
Rep Power: 6 |
thank you very much for your kind reply , i tried what you have suggest but the problem is still there
May 29, 2022, 12:03 |
Alain Islas
Rep Power: 6 |
You can send your files at alain.islas@gmail.com. I can take a look at them and see if I can do something
May 30, 2022, 13:50 |
#7 | |
Sakun
Rep Power: 6 |
many thanks for your help |
3d meshing, ansys meshing, compressor blade, icem |
[ICEM] Bad orthogonal quality in ICEM | Vladimir Hassan | ANSYS Meshing & Geometry | 1 | May 16, 2021 16:57 |
How to improve mesh quality? | Oula | FLUENT | 2 | March 7, 2019 05:00 |
[ANSYS Meshing] Min. orthogonal quality with zero number of elements? | fjtb | ANSYS Meshing & Geometry | 2 | April 18, 2018 04:08 |
Improve Mesh quality - airfoil simulation | Lukas84 | STAR-CCM+ | 4 | July 6, 2010 10:07 |
Improve smoothness & quality of structured grid | quarkz | Main CFD Forum | 2 | March 10, 2007 15:26 |
