April 15, 2013, 03:16 |
Merge Mesh
Javi
Rep Power: 16 |
I would like to know if "merge mesh" works with hex/hex mesh or at least one of this must be tetra/tri mesh? |
April 15, 2013, 04:01 |
AB
Rep Power: 21 |
If you want to merge Hex mesh with another Hex mesh, you need a conformal interface between the 2 meshes (i.e. the exact same interface with the exact same node repartition), and then use the "merge nodes" option rather than "merge meshes".
April 15, 2013, 06:55 |
Javi
Rep Power: 16 |
I´ve tried to do something similar. I have my entire domain split into 3 parts. First, I´ve done the first blocking and first mesh. I´ve saved blocking and mesh. Second, I´ve done the second blocking (merging blocks) and the second mesh and I get this. So..I think something wrong because the second mesh is (only a part) like the color of first one. Do you know why is it?
April 15, 2013, 12:51 |
Javi
Rep Power: 16 |
Sure. I have the entire domain divided into 3 parts. First, I do the blocking and mesh in first part. I save the blocking and mesh then close the block and mesh. Then I do the same with the second part of the domain.
But as you can see, in the first part in "Interface 1", no problem. But, on the second mesh, "Interface 1" is a sector only. The rest is associated to another part, instead of associating the "Interface 1" (as in the mesh 1)... I´m not sure if I explain well. I´ve tried to follow similar approach like "Merged Tetra-Hexa Mesh in a Hybrid Tube" tutorial. Maybe the problem is the curves association... |
April 15, 2013, 13:30 |
Ghazlani M. Ali
Rep Power: 28 |
i have more questions: What do you mean by sector only ?
Why did you separate the block in three part ? Did you try merge blocks ? Can you share your project using the public dropbox file ? |
April 15, 2013, 14:02 |
Javi
Rep Power: 16 |
I separated the blocks because is easier to do the block on transition part of my blade. For this reason I´ve not tryed merge blocks. I´ve tryed to do something similar to BrolY told me. Yes, I´m going to share the project but right now dropbox isn´t work well.
April 15, 2013, 14:06 |
#9 |
Javi
Rep Power: 16 |
at first, you can view the premesh in part 1. Then, you can open the block "bloque 2" and merge it.
Then view the premesh in this second block. https://www.dropbox.com/s/yofo3a4vwe...MergeMesh1.rar |
April 15, 2013, 14:17 |
#10 |
Ghazlani M. Ali
Rep Power: 28 |
Are you aware that you have overlapped surfaces... for one block it may be part of interface_1 and for the other one it may be part of FLOW_DOMAIN_TRANSITION
you can fix that, by doing a doing a build topology in the repair geometry... |
April 15, 2013, 14:59 |
#11 |
Ghazlani M. Ali
Rep Power: 28 |
take a look at my blocking without splits:
Project file is here: https://dl.dropboxusercontent.com/u/...MergeMesh1.zip |
April 15, 2013, 15:50 |
#12 |
Javi
Rep Power: 16 |
Thank Diamondx, you´re right. I have overlapped surface. I´ve delete them and now I think it´s ok.
Understood. It is better not split. I guess you get with 2 O-grid through the ends and then with a horizontally split? It is? |
April 15, 2013, 22:27 |
#13 |
Ghazlani M. Ali
Rep Power: 28 |
ok; i could make another blocking similar to the one in youtube (by simon). minimum quality is 0.4, it can be improved more
link for the project is here: https://dl.dropboxusercontent.com/u/...MergeMesh1.rar |
April 16, 2013, 02:51 |
#15 |
Javi
Rep Power: 16 |
That is the problem area. Because for a cylindric section O-grid is the best. However, for the other part of the blade not .. so ... how to make a block support the other... I mean how to pass from one topology to other one
April 16, 2013, 03:12 |
#17 |
Javi
Rep Power: 16 |
But I need a sharp trailing edge so... I think here is the problem
But... I think Diamondx managed it! |
April 16, 2013, 04:17 |
#19 |
Javi
Rep Power: 16 |
Thank you dimaondx!
You get a good quality in all blade. But why do you create top and down part? I supposed that is because this part is hard to adjust but i´m not sure... Thanks again! |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Technical] How to crop a mesh or merge layers | Opxah | OpenFOAM Meshing & Mesh Conversion | 1 | May 31, 2011 07:32 |
[ICEM] Merge mesh - non manifold vertices | BrolY | ANSYS Meshing & Geometry | 4 | October 30, 2010 22:07 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
